Spec-D Headlight Bulb Replacement Question
So the new headlights from Spec-D come with an H7 bulb and it seems like it works as both a high and low beam. I want to replace this with an HID kit or at least just change the color and output since I'm used to driving with HID's, but I do not know which kind of kit I would need. Any kind of info would be useful. I've emailed Spec-D and theretrofitsource about it but they haven't given me a clear answer on what I should do or need.
OEM Headlight Bulb Sizes:
2005 - 2007 Scion tC
Low Beam: 9006
High Beam: 9005
2008 - 2010 Scion tC
Low Beam: H11
High Beam: 9005
2011+ Scion tC2
Low Beam: H11
High Beam: 9005
2004 - 2007 Scion xA
Low Beam: H4 / 9003
High Beam: H4 / 9003
2004 - 2007 Scion xB
Low Beam: H4 / 9003
2008 - 2012 Scion xB2
Low Beam: H11
High Beam: 9005
2008 - 2012 Scion xD
Low Beam: H4 / 9003
OEM Fog Light Bulb Sizes
2005-2010 Scion tC
H11
2011+ Scion tC2
H11
2004 - 2006 Scion xB
9006
Source - http://www.fastscions.com/onex-hid-c...on-models.aspx
So side note about Spec D headlights they are not HID ready. What that means is you may have to do some cutting where the bulb goes into to make them work. I wanted to get Spec D for my car but I called them and they said HIDs will not be a direct fit into them. They also said that HIDs might destroy them after awhile because they are not built to withstand the heat that HIDs put off. There are companies out there that have HID ready headlights.
