Tc2 Ccfl Halos: Just a feeler
Hey guys, just throwing this out there as a feeler. How many people would be interested in doing their headlights with single or dual Ccfl, single or dual led halo rings? Me and a buddy are thinking of doing these. Just wondering if anyone would be interested. Post up if your even just a little bit interested.
TRS sells COB Rings (Chip on Board) these will be brighter and come on instantly. The website only lists Amber and White but they can special order different colors, though anything else is illegal.
http://www.theretrofitsource.com/pro...ducts_id=14906
If your going to bake open the headlights you might want to get the "Black Series" Clear lens to replace the frosted OEM lens installed, clear lens will sharpen the cutoff and provide more light from your HIDs.
http://www.theretrofitsource.com/pro...ducts_id=25696
Yes, risky baking them open again. If someone were to contact Matt at TRS and ask for a black series lens for some comparison pics, TRS likes to show off the change from Frosted OEM to Clear lens. Tell him Will Davidson sent you they might discount a set.
http://www.theretrofitsource.com/pro...roducts_id=792
TRS also makes a Morimoto MH1 quick retrofit kit for the TC2, but it uses the H1 aftermarket bulb which is still a problem. OEM D2S HIDs are far Superior in quality and alignment. OEM anything make a world of difference when it comes to headlights!
I have a 2007 GTI and I did a complete retrofit, Color painted shrouds, clear lens and shield modification. it was a mission to get a sharp cutoff. On the GTI you can remove the projectors from the back of the headlights making easier to run sevral aiming and focusing tests, On the TC however, once the headlight is sealed you will have to reopen it again to make any adjustments.
I been looking into doing halo rings and upgrade to clear lens but here are my concerns
1. Will the clear lens installation require shield modification and aligment? or do the lenses just snap in?
2. Not sure if CCFL is the way to go. I been looking into LED rings instead since they last longer.
3.Not sure the exact diamaeter of the Halo rings. Does anyone know the right size please fill me in...
I also been wanting to open the headlights and somehow create an exact LED running light just like the LEXUS IS, I been looking for the right color LED and trying to find a way to create some LED reflectors to fit inside the TC headlights.
yea I did my Halos they are multi-color LEDs and I think they are way better then the CCFLs.
for which ring do you need the diameter?
and about the resealing, when I did mine I opened and resealed mine 4 times and I just put extra silicon to make sure they are sealed right and have never had a problem with them =)
Unless you want retrofit OEM projectors or spend the money to have someone retro for you I would just do the clear lens upgrade and buy some good HID's bulbs and call it a day.
I have a 2007 GTI and I did a complete retrofit, Color painted shrouds, clear lens and shield modification. it was a mission to get a sharp cutoff. On the GTI you can remove the projectors from the back of the headlights making easier to run several aiming and focusing tests, On the TC however, once the headlight is sealed you will have to reopen it again to make any adjustments.
The clear lens will just snap into place and the alignment will be perfect. No shields mods are needed but you might as well close the squirrel finders to avoid the glare.
COB LED rings will be brighter and wont require the inverter, they however have a voltage regulator puck.
3.Not sure the exact diameter of the Halo rings. Does anyone know the right size please fill me in...
http://www.hidplanet.com/forums/foru...y.php?13-LED-s
Team318 used a 90mm I believe, but I used a 80mm for mine. I have Muliti-color Led Halos though if you want to check how they look heres my build thread, hope it helps
https://www.scionlife.com/forums/sho...d.php?t=219180
Really hard to answer that honestly since I haven't worked with the Bi-X MH1 or the TC2 halogen projector, but for ease of use stick with the halogen w/Clear lens upgrade and get some good HIDs. This saves the alignment factor when you achieve a sharp cutoff, it's not easy getting both beams to align properly. TRS has 2 styles of the H11s HIDs now that are much better then most other aftermarket HIDs you can by at a cheaper price. You might wonder why I keep referring to TRS? Well they're here in Atlanta so I have hands on access to alot of products for testing. I started with my OEM headlights installing the DDM Raptor kit, replacing the bulbs with eBay crap and so on, Only to learn that the quality and alignment of rebased HIDs matters!!
Quick question though, I see there is an option for a spacer tuning kit with that black series lens. What is that for?
I want halos but to bad someone wont make a whole headlight kit to where we don't have to bake them and do them ourselves. we should be able to pop stock headlights off and put new headlights with halos on. id buy them(just a thought)
