TC2 fog lights water/condensation issue.
Well its been almost 2 weeks with the fog lights installed and I am already having condensation in both fog lights after washing the car and sometimes after it rains.
Anyone having this same problem?
Have you bumped into anything on the front bumper.
I have seen lenses that were BARELY tapped (not even considered hit) and broke a seal and caused condensation. If you havent hit them, is there the possibility on returning them or exchanging them???
They are not OEM fog lights from the dealer. I got them from TRDSPARKS.
I did contact the company and they asked for pictures of the fog lights with water in them in order to issue a replacement set. To my best of luck they just cleared up but I am going to spray them
with a lot of water to see if they condensate again.
LoL now I know why they are called FOG lights... -__-
Well update. I used all these 3 things to seal them
3M window ribbon sealer
foam sealnt rope
Aluminum a/c tape
I washed the car today and not 1 drop of water inside the housing. I did notice something else though. Since I am using CREE LED bulbs I noticed the rubber gasket that goes around the base of the bulb did not make a tight seal compared to the stock halogen bulbs. I swapped the red rubber gaskets and the LED bulb now fits tighter
foam sealnt rope
Aluminum a/c tape
FML!!!
It wouldn't go away unless I removed the bulbs and blow hot air inside.
I am almost 100% sure the water was getting in through the light bulb seal and
the rest though the vent hole on the back of the fog lamp.
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 01:41 AM
carid
01-08-2015 11:33 AM
