Confused about Sport Mode
Old 12-15-2012 | 03:20 AM
yoToco94's Avatar
Default Confused about Sport Mode
So Ive a 2013 tC Automatic. Why is it that when I go sport, it says is on 4th gear? Is there any way to set it that when I got sport in 2nd gear, it says 2? Also been in sport means I control the shift, well sometimes I shift and it doesnt shift, it shift after the revs get higher. :S Or maybe is me? I dont know.
Old 12-15-2012 | 03:48 AM
Kyleptrsn1's Avatar
Sorry man, can't answer this one. I have a manual, I can shift whenever I like. I wish you luck in figuring it out though.
Old 12-15-2012 | 03:53 AM
yoToco94's Avatar
Silly question, do u know how much can it cost to make it manual? Hahaha
Old 12-15-2012 | 03:58 AM
Kyleptrsn1's Avatar
Hasn't been done that I know of. Give world racing a call, they may be able to help you out. Although it might be easier to go to the dealer and tell them you've decided you want a manual instead.
Old 12-15-2012 | 04:00 AM
yoToco94's Avatar
I dont think they would get my car for another one. xD I mean Ive it since July and its all stock with less than 5000 miles in it.
Old 12-15-2012 | 04:34 AM
o TaGGeD o's Avatar
You could do it be a heck of alot cheaper than making it manual
Old 12-15-2012 | 05:31 AM
Diffraction's Avatar
4th gear is what the car is currently in when you switched it to sport mode. pretty sure 4th is the most common gear on the automatic transmission when normal driving, so odds are that when you slap it to sport, it will be on 4th. also, the sport mode is a bit sluggish. there's a short delay when the gears shift. pretty sure i'm correct. this is all from experience so someone correct me if i'm wrong haha
Old 12-15-2012 | 12:08 PM
yoToco94's Avatar
Thanks for answering but I think you may br wrong cuz if we turn the car on and without driving, we go to D and then Sport, it says its 4th gear even when we havent start to move. :S
Old 12-16-2012 | 05:29 PM
talt2008's Avatar
I'm pretty sure that 4th gear is just used for the safety of the transmission and engine. My reason being that if you were driving at a high rate of speed and switched it to sport you would probably damage something if it put you into 1st gear. I don't have the automatic, but any toyota I have driven with slap shift has always gone straight to 4th gear when put into sport. That applies to both 5 & 6 speed
Old 12-16-2012 | 07:32 PM
yoToco94's Avatar
Ohhhhhh ok. Well my tC has the paddle shifters equipped and if Im on D and hit the low shift paddle, it changes to manual but doesnt lower the shift and there I can keep up shifting up and down depending on what I am doing. And if I do that and change it to sport then it would stay on the gear that Im currently in. Weird huh? xD
Old 12-16-2012 | 09:38 PM
hm. i have slapped it over on second and third gears before. does this mean my tC is weird
Old 12-16-2012 | 10:40 PM
yoToco94's Avatar
Can you take a video about that and post it here? So we can see our differences. xD
Old 12-18-2012 | 04:43 AM
jsiv's Avatar
what you said is true, there is a delay between shifting in sports mode.
Old 12-18-2012 | 07:09 AM
Team318's Avatar
They all start on 4th gear, whether you just start it or not. There's nothing wrong with it.
Old 12-19-2012 | 02:41 AM
yoToco94's Avatar
Is there any way to set it to start in the gear it suppose to?
Old 12-25-2012 | 04:58 PM
Cal3000's Avatar
There is no way to do that. It will always be 4th.
Old 12-27-2012 | 05:55 AM
11tcowner's Avatar
Default An answer for you
I drive the 2011 scion tc. It is also an automatic and the sport mode is the sequential mode. I drive in sequential all the time. The reason why it automatically switch is so when your going at a higher rate of the speed and put it in sequential it goes to fourth gear so that you don't blow your tranny because in 4th gear it can go up to bout 120 or something crazy like that. Idk check your manuel for speeds. Also if your going like 30 or something it will go to third gear. If your doing sequential and wanting to gun it right off the start. 1st gear will get you to 30, 2nd gear will get you to 60, 3rd to 80, 4th up to like 110 or something. and the max allowed speed for 5th is 125 (claimed in the manual.)
Old 01-03-2013 | 06:36 AM
izzy209's Avatar
what i dont like is not being able to downshift to first untill you drop to 20
Old 01-03-2013 | 04:50 PM
11tcowner's Avatar
That is so that you don't blow the transmission because there is quite a bit of rpm. I just stay in 2nd till i come to a stop
Old 01-03-2013 | 04:53 PM
o TaGGeD o's Avatar
Best solution yet get a 6 speed manual and leave the automatics for the chicks
