Injen CAI.
Old 03-31-2011 | 06:58 AM
  #101
svsveng's Avatar
Which is the best site to order the SRI ?
Old 03-31-2011 | 03:59 PM
  #102
donsun's Avatar
you should try reading through the thread. it helps sometimes..
until 3/31 the cheapest deal should be autoanything.com they have 10% off and free shipping I believe along with a free water-repelling pre-filter.
Old 03-31-2011 | 04:45 PM
  #103
svsveng's Avatar
Thanks i did read through just was really thinking straight
Old 03-31-2011 | 11:55 PM
  #104
Enzie's Avatar
Does anyone know how much HP the Injen CAI/SRI makes? I was trying to find it but i just cant seem to find info on it. And i saw that the Takeda is supposed to add 11hp and 11lb torque, so i want to know who's is the best performance wise :D
Old 04-10-2011 | 05:25 AM
  #105
WD0100's Avatar
gains of up to 9 hp, but i dont know if its for the cold air or short ram or both, i found it here http://www.injen.com/Galleries/ProductPress/SP2116.jpg
on autoanything.com the short ram intake is 176.95, so im thinking to buy it since i just read that descendant is only planning right now for the cold air intake but i want a short ram...
Old 04-10-2011 | 05:34 AM
  #106
Enzie's Avatar
^^^ Ohh thanks for the info.. I'm was actually thinking the same thing as you. I wanted a descendant, but I need a SRI
Old 04-10-2011 | 05:35 AM
  #107
Papa_Bear's Avatar
on autoanything.com the short ram intake is 176.95, so im planning to buy it since i just read that descendant is only planning right now for the cold air intake but i want a short ram...
Doing a side by side comparison video of the injen and descendants in the middle of next week. I'll post up when I do but I'm just not happy with Injens play on the MAF sensor. It makes it run much too lean especially earlier in the RPM range. I'll be switching the descendant from the injen as soon as it comes in.
Old 04-10-2011 | 06:00 AM
  #108
Enzie's Avatar
Good to hear, i dont really like the sensor thing everyone is talking about regarding the Injen intakes, maybe Takeda's wont be like that when it comes out.
Old 04-10-2011 | 04:07 PM
  #109
Magnetic_Grey's Avatar
One site:
http://www.jscspeed.com/catalog/Scio..._Scion_tC.html
has the injen CAI listed as gains of 9hp, 8ft-lbs of torque. Whereas the SRI was 7hp, 7ft-lbs of torque. Personally i'll take the SRI that gets slightly less power, but safer with regards to waterlock.
Old 04-14-2011 | 02:54 AM
  #110
Blackedout011TC's Avatar
Papa Bear or anyone else for that matter, have you pulled the spark plugs to verify a lean condition? Your theory on the tube by MAF sounds spot on. Just curious.
For now I'm sticking with the K & N drop in filter and modding the stock intake box for more flow. The most restictive part is the snorkel on the side of airbox. Way too small IMO.
Old 04-14-2011 | 04:20 AM
  #111
Papa_Bear's Avatar
There isn't really a need to pull the plugs. It goes lean and insaw it on there dyno with the sideband in the exhaust. It's around 11.1 stock and 12.3:1 with this but under about 4500 or so it's closer to 14~:1 which is way too lean at any point under wot. 14.7 is good at idle but never under wot as the stock ratio is at 11:1 in the same spot.
Old 04-14-2011 | 06:43 AM
  #112
Gotcha, that's proof enough!
Old 04-14-2011 | 07:01 AM
  #113
Papa_Bear's Avatar
Don't worry I wouldn't give people false info on something like that especially since I sell it lol . I should have descendants intake next week
Old 04-14-2011 | 07:19 AM
  #114
I apologize if it seemed that I was calling you out on that. I must have missed the dyno info. somewhere along the way. Thanks for clarifying!
Old 04-14-2011 | 07:26 AM
  #115
Papa_Bear's Avatar
Haha I didn't think that. I'm here to share my knowledge with everyone and help out. Let me know if you have any other questions!
Old 04-14-2011 | 02:38 PM
  #116
donsun's Avatar
you could wait for the weapon-r and see how theirs comes out since I'm pretty sure it'll be a SRI
Old 04-25-2011 | 05:53 AM
  #117
WD0100's Avatar
i got the injen short ram for 172. im having fun with it so far, also the engine sounds louder, especially in second and third gear, over 3k rpm. it is normal right? lol...
when i got i had to wash it inside the tube, it was very dirty, with some black stuff, may be from the welding... so i guess they forgot to cleaning it inside.
Old 05-31-2011 | 05:24 PM
  #118
Scratch's Avatar
Not sure if Papa_Bear will be back on here after the water issue on the Injen CAI, but now that the Descendant SRI/CAI is out as well I wanted to look further into the MAF Sensor manipulation and the tC running lean after the Injen SRI is installed.
Just from looking at the install pictures of the Injen and the Descendant, the MAF looks to be in the same spot, so asking if there is a major difference with them installed/dyno'd? Also curious if anyone has gotten a dyno result with the Descendant installed?
Same goes with the Weapon R, or any other intake, not including the TRD since it has a totally different configuration.
Old 05-31-2011 | 08:01 PM
  #119
Papa_Bear's Avatar
Scratch, the MAF manipulation is within the intake of the injen. It's a small tube in the intake that tricks the MAF in to thinking less airflow is going through then there is which is where the lean condition comes in.
Old 05-31-2011 | 08:29 PM
  #120
Scratch's Avatar
Thank you for that, so we should be looking at the insides of these intakes to see who is trying to pull what... and by that logic, can one modify the Injen to remove or reduce the faked air flow and thus the lean condition?
Just asking, as of today I don't have the Injen in front of me so I have no idea if it would be possible.
