tC2 ACT clutch kit now available at PTUNING!!
We are excited to offer the new ACT clutch kit line for the 2011 tC2
We have just about every clutch option available from ACT. Whether you are looking for an oem replacement clutch, or a clutch for your race car we have a solution for you.
-ACT’s 10 new clutch kits for the 2011 Scion tC include a Heavy Duty
or Xtreme pressure plate, a choice of disc and an alignment tool. Both
the Heavy Duty and Xtreme pressure plates incorporate hardened
diaphragm fingers for decreased wear and provide a 29 to 61 percent
increase in clamp force over the stock unit.
-The ACT Street clutch kits combine the Heavy Duty or Xtreme
pressure plate with a performance organic street disc. The disc
features special performance organic friction materials able to withstand increased heat and abuse, steel-backed linings
for high-burst strength and modifications engineered for quicker shifting. The ACT Street clutch kit provides a moderate
and consistent pedal feel, smooth engagement and significantly improved durability. These kits meet SFI Spec 1.1 and
have increased torque capacity between 310 and 390 lbs./ft., depending on the pressure plate selection.
-The ACT Race clutch kits combine the Heavy Duty or Xtreme pressure plate with a cerametallic Xtreme Race disc, which
is available in 6- and 4-pad spring-centered and rigid-hub designs. These discs are very durable while allowing for quick
shifting. The Xtreme Race discs are for high-powered engines and recommended for track use only. The ACT Race clutch
kits meet SFI Spec 1.1 and will hold 400 to 500 lbs./ft. of torque, depending on the pressure plate selection.
or Xtreme pressure plate.
Description Part No
-ACT Heavy Duty Street Clutch Kit TC8-HDSS 310 lbs./ft. 29 %
-ACT Heavy Duty Race Clutch Kit (6-Pad Spring-Centered) TC8-HDG6 400 lbs./ft. 29 %
-ACT Heavy Duty Race Clutch Kit (4-Pad Spring-Centered) TC8-HDG4 400 lbs./ft. 29 %
-ACT Heavy Duty Race Clutch Kit (6-Pad Rigid Hub) TC8-HDR6 400 lbs./ft. 29 %
-ACT Heavy Duty Race Clutch Kit (4-Pad Rigid Hub) TC8-HDR4 400 lbs./ft. 29 %
-ACT Xtreme Street Clutch Kit TC8-XTSS 390 lbs./ft. 61 %
-ACT Xtreme Race Clutch Kit (6-Pad, Spring-Centered) TC8-XTG6 500 lbs./ft. 61 %
-ACT Xtreme Race Clutch kit (4-Pad, Spring-Centered) TC8-XTG4 500 lbs./ft. 61 %
-ACT Xtreme Race Clutch kit (6-pad, Rigid-hub) TC8-XTR6 500 lbs./ft. 61 %
-ACT Xtreme Race Clutch Kit (4-Pad, Rigid-hub) TC8-XTR4 500 lbs./ft. 61 %
For further clutch options click on the following link:
http://www.ptuning.com/html/search-r...l=tC&Brand=act
Classifieds thread:
https://www.scionlife.com/forums/sho...25#post3925625
Drew
Doug Ptuning
Recently I've changed the clutch ACT Heavy Duty Street Clutch Kit TC8-HDSS 310 lbs./ft. with short shifter TWM performance. The difference from the original clutch is great! The speed, smooth gear shift became much more better. The clutch pedal is hard, but i guess it will be okay someday.
Thank you very much ptuning!!!
more photos
more photos
Xaphoon
01-17-2015 02:12 AM
