10 psi?
yes
maybe im lucky, but ive haved strong boost creep for over 4 months now, with no problem. with a 9lb spring i make 9psi at about 3200 rpm and 16psi at about 5500. Yes, it gets lean (about 14/1) at 5k rpm.
Anyway, point of the story is, if you have good gauges you can spot the majority of problems (boost related) before they arise.
P.s i just shift earlier
you drive a 2010 tc correct... this is for a second gen tc 2011-up therefore we have 2 different engines 2 different cars so your post is utterly misguided and should not have been posted in this section please if your reading this do not rely on this as reliable information
Anyway get ur car professionally tuned.
Wrongo! Super genius. It doesnt matter if I was driving a boosted Mac truck, that wasn't the point. Guages! Installing and understanding, oil pressure, vac, afr, and a good thermostat is the only way to understand whats going on under your hood. How do you think professionals ( n tuners) know how much they can run. I don't think they read it off any forum.
I got my car weighed when I PCS'd to AZ(bone stock). New hood full exhaust system pulled a ____ ton of paneling heat shielding and carpet wheels rotors washer pump and fluid (kept ac) after my sun roof got smashed in by a eBay CF hood I installed a stationary from a spec, engine port job, no tools or spare. A bunch of random little ____ all adds up.
It's always really loud in my car, but on the plus nothing rattles. My new fuel pump is audible but it's not too bad, unless I pull my back seat out (64lbs btw) then its loud as ____. It rides great but some people can't stand the exhaust note inside the cab. I'm use to it, i actually kinda enjoy it because I can tell immedently if something's off (if I'm not eyeing my GAUGES).
It's always really loud in my car, but on the plus nothing rattles. My new fuel pump is audible but it's not too bad, unless I pull my back seat out (64lbs btw) then its loud as ____. It rides great but some people can't stand the exhaust note inside the cab. I'm use to it, i actually kinda enjoy it because I can tell immedently if something's off (if I'm not eyeing my GUAGES).
I agree with you that no matter if you're turboing a tc1, a mac truck, or whatever that what you mentioned applies. I spend a lot of time reading the tc1 forced induction forms to learn from you guys. Thanks for your input. Gauges are a must.
Wrongo! Super genius. It doesnt matter if I was driving a boosted Mac truck, that wasn't the point. Gauges! Installing and understanding, oil pressure, vac, afr, and a good thermostat is the only way to understand whats going on under your hood. How do you think professionals ( n tuners) know how much they can run. I don't think they read it off any forum.
the question did not ask all of that though yes having guages and being able to read them does help but when your asked whether a tC2 can withstand 10 PSI without rebuilding the engine then you your tc1 experience with your engine being able to withstand so much does not make a matter and yes professionals do use the gauges to know how much to push but as a daily driver you dont want to accidentally ____ something up because someone driving a completely different car said oh it will be fine as long as you look at your gauges
But devanb3 is right, don't believe anything you read online.
Give this topic a search. 10lbs is ok on good tune but if your driving the car all the time, your fine with 8lbs on a stock engine. Its been done since 2005 - If it overboosted for some reason, you have room to play with. Tune it for 10lbs and kick it back to 8-9lbs. The car is plenty quick at that. When you have over double the hp, as the stock car, your gears are all wrong. I had a 300hp tC with limited slip and could slam all thru second. It was fun but the turbos have a lot more torque spike (compared to my s/c). Keep the car stock looking w/ the dezod kit and you will fool most people by a lot.
Sent from my iPhone using Tapatalk
Hydryman
02-23-2016 04:35 PM
