Affordable 2ARFE connecting rods!
http://www.dezod.com/pd-molnar-technologies-h.cfm
http://www.dezod.com/cat_pistons.cfm
http://www.dezod.com/pd-cp-performance-piston.cfm
Paul i see two type of piston on the dezod website..which one is the best option if i want 400whp to 500whp. Do i have to take the motor out the car to install, or just valve cover to get to it. Also with just piston and rods will i get 400whp with the basic dzod kit. Do i need to do anything to the motor to install the piston and rods. Do i need to upgrade fuel pump or bigger injector. I have a tc2 rs8 6speed i am planning on my build when i save enough.
i have an extra 2ar block for sale, ill give you a really good deal if anyones interested. pm me! its 2800 brand new at toyota and this one comes with three good stock pistons and rods.
Each piston and rod set is sold in a set for the engine. So purchase one of each item on the website. ![Redface](https://www.scionlife.com/forums/images/smilies/redface.gif)
If you are going to build the motor, I would recommend removing the engine and doing a complete overhaul. It's easier to crack it open once, build it and run the day lights out of it with no worries in sight.
Anytime you are going to make significantly more power than stock, you will need to upgrade the fuel system accordingly.
Correct on the fuel system, not correct on the coils. These factory Toyo coils are stout and work well. Used factories up to 450whp on some TC1s.
Bigger wastegate? No. Not true. That may be contingent upon someone else's design, but not ours...
True
upon building your motor you will need bigger injectors, fuel pump is a must if you wanna run more than 12 psi, coil packs, engine management system[best bet would be a standalone], bigger wastegate or have a shop custom weld the manifold to fit two wastegates, bigger intercooler, and some other ____ too possibly.
im pretty sure dezod sells them in a set of four.
BlingSlade
10-19-2016 12:39 AM
