Opinion on STS turbo Kit
I came across a article about STS turbo it's rear mounted turbo system that claims to get more WHP per pound of boast than front mounts kits. My thing is if it was sooo good why can't I find videos or articles about this kit with the import market Scion Honda etc. if any one is familiar with this kit shed some light on the subject pro or cons if possible.
I've heard of them and saw them on many muscle cars camaros and trans ams mostly not sure exactly how they work you'd have to do an entire custom build prob not enough exhaust back pressure on a 4 banger
I understand that it is more common on bigger engines but turbo is turbo no matter where it's located. I seen a threat talking bout this type of kit but no real solid answer. So it was time for some investigating I gave STS a call and spoke with there sale guy Ben because I wanted to know if they very boasted any imports. He said that they did couple import but not as much as domestic cars. Im in the south florida area he said a local brother shop did a install I'm waiting to get the videos so I get see for my self if this kit is even a contender vs descendant and other front mounts.
A turbo is a turbo at the end of the day, but how it functions based on its location is where it differs. STS, you will have turbo lag due to the turbo being further away from the output of the exhaust gases, then you have charge pipes that are long thus increasing travel time to the intercooler, then into the intake manifold.
I would consider our kit any day over an STS kit.
http://www.dezod.com/pd-dezod-scion-...rbo-system.cfm
I wasn't siding with the STS over front mounts kits. I'm just the type person that need to do research and questions all things. Lol. I didn't know descendant no longer doing kits for us, I've been off SL for a while now.
Nothing wrong with that you end up with a better build and understanding
If you go STS your going to spend more than buying a bolt on kit from ptuning or dezod ( descendants out of the scion game) and ontop of that you will make less power and not even be able to show off your turbo unless its on a lift rofl it's pointless other than to be different and having a turbo tc makes you different enough as it is not alot of guys turbo these if you look at the ratio of Na/boosted lol
Get a side mount like I've got from the descendant kit if you want stealth don't waste $ on sts lol and Everyone I've talked to that's boosted there tc2 has yet to have issue well everyone running 10psi and under
And the above picture, where is the charge pipe?
cessblood
09-15-2015 07:50 AM
my06tc
06-25-2015 01:18 AM
