Hertz Audio 3-Way component speakers installed
If you want to add subs that don't need that much power, or space, and have excellent clarity, the alpine 8" Type R's that came out this year are hard to beat. I'm using one in my truck right now on a very cheap amp, and it is very good. They don't have a vented pole on the basket, so you can bottom them out in an enclosure. They only need a .30 gross cu. ft. sealed enclosure as well. I'm likely to have 4 of them in my car when things are all sorted out.
The Alpine 8" if i remember them right might get a little lost in your set up depending on the x overs you have now.
Great sub but if you have a trained ear 10" or 12" for stand up bass or a kick drum is needed from the rear of the car for you to really get what to hear.
Thats why we shoe horned 8" in the doors and are just loving it. the 95% up front base with the 10" in the rear for low fill is so nice.
alpinedb i just bought my tc2g and was thinking about upgrading the speakers. I have the scion nav system in mine so i am not going to upgrade the HU, i hope this one will be fine. How are the hertz you have? Did the adapter for the 6.5" work well?
Also if it is not to much trouble how did you get your door panels off and was it a pain? Sorry for all the questions.
Russell, Sorry for the long reply. I've been off the forums for a couple of days. I considered the focal 3 way set up with the 4 inch, but I passed cause the 3 inch stock adapter fits the hertz 3" midrange perfectly. I mounted the midrange with high strength epoxy glue. The 6.5" adapter is a perfect fit, but you will need a nut and bolt to hold it up. The stock 6x9 is mounted with a pain in the ___ bolt that you can't unscrew. I ended up just snapping it out by brute force. Lol. The door panels are very easy to get off. There are three screws and then it snaps right off. One is located behind the door handle. You snap out the plastic cover. Two other screws are behind the silver trim on the door handle. You need to snap that out, but be careful. I had trim/panel removing tools for this so that I wouldn't scratch or damage my interior.
I have 2 pairs from the amp on the backseat to the crossovers underneath the passenger seat, I have 3 pairs running from one crossover underneath the carpet through the doors. I have another 3 pairs running from the other crossover, underneath the carpet through to the other door. So I have 8 pairs in total. There's input, woofer, mid and tweeter = 4 and just multiply that by 2. Keep in mind this is just speaker wires and not the RCA cable, power, ground, and remote.
Okay the model number is 99-8230
EDIT: Yep, here it is. 2008 xB single din kit will fit tC2.
https://www.scionlife.com/forums/sho...48&postcount=7
I did not have to do that and wires were not run from behind the dash. They were run from the crossovers which are located underneath the passenger seat. I went through the rubber grommet from the chassis of the car to the door. It was a pain and probably one of the most time consuming parts of the install aside from the sound deadening.
Anyone know of a box, other than the JL one, that is on the side and out of the way or down by the spare? I was to add some bass to my ride but dont want to take up the trunk space. Also I added the Focal A 165 3 way component system to my doors and they sound great, powered by Rockford Fosgate PBR300X4. Great tiny amp that powers everything!
