Installling Pioneer AVH-P4300DVD
Ok guys, not sure if anyone can help but here goes. I've bought a Pioneer AVH-P4300 and I think I'm the only one that bought the Scosche dash kit to install it. It looks like I'm going to have small gaps above and below the radio and the trim piece Pioneer gives you with the radio isn't sized right. Just wondering if anyone could give me some advice on making this look extremely clean. I'm a bit OCD on things like this.
There's a few of us already that have the 4300 installed. It installs clean with the Scosche kit. In order to make the 2 pieces fit flush however, you need to sand down the the inside of each piece so they're flat.
There should be a small grey one, that's for the vehicle USB and AUX connection. The other small white multi-pin connector is for the steering wheel control. KidJustin used a kit to tap into his so he could keep his wheel controls, I didn't think it was worth the hassle even though he said it was easy. He also cut and spliced his USB cable to keep his factory connection. Again I chose not to as I didn't want to cut up my wires.
Also with the scosche wiring harness, be sure to connect the headunits blue 12v switched source to the harnesses blue wire, otherwise the factory amp under the drivers seat will not turn on.
I use the Metra Axxess ASWC.
Install guide:
http://contentdocs.installernet.com/...icle/10957.pdf
You need 3 wires from the 20pin connector behind the radio to connect to. Then connect ground and 12V. I just spliced into the Pioneer wires for ground and 12v.
Another thing you need to do is remap the buttons. The ASWC auto programs the preset up and down as seek up and down.
It tool about 30mins to install for me
Install guide:
I have the Axxess ASWC. Works with select Pioneer, Sony, Alpine, Kenwood, Eclipse, JVC, Clarion, Dual, Jensen, Visteon, and Valor headunits.
Vehicle Information
Resistance Type Control System YES
Reference Ground Wire Color GRAY
Reference Ground Polarity (-)
Reference Ground Location RADIO HARNESS
Reference Ground Pin # C6
Control Wire 1 Wire Color YELLOW
Control Wire 1 Polarity (-)
Control Wire 1 Location RADIO HARNESS
Control Wire 1 Pin # C7
Control Wire 2 Wire Color LIGHT GREEN
Control Wire 2 Polarity (-)
Control Wire 2 Location RADIO HARNESS
Control Wire 2 Pin # C8
Vehicle Information
This harness retains the factory aux in and also give you the steering control wires without splicing into the factory connector. And if your using the metra ASWC that black plug on top is straight plug and play, only connecting you have to do other than plugging it in is wire +Ign/-Ground for power and that is it.
70-8114
7.99 @ SonicElectronix
70-8114
Hydryman
02-23-2016 03:35 PM
BBesco2021
Scion tC 2G ICE & Interior
08-13-2015 03:23 AM
semlin
07-29-2015 02:07 AM
