Looking for Racing Pedals...
#42
Well, looky looky what I found...even comes with a dead pedal. http://www.ebay.com/itm/Sport-Foot-M...f4d777&vxp=mtr
Installed:
Installed:
#45
#47
Here's the install thread where I heard about them. If you can find a set, apparently they're good quality.
#48
Installed:
Installed:
#53
#57
Finally, my new TRD drill-in racing pedals arrived, and I think they look awesome !!! The metal on the pedals is nice and thick, and so is the rubber, which means these pedals are good quality. You can feel the rubber pop-ups even through your shoes so you know you have a good grip. Comes with all the hardware for installation but I used some thicker, shorter M4 countersunk screws with lock nuts for mine. The rubber on the stock clutch and brake pedals comes off easy by pulling up on the bottom corners together. The gas pedal is a piece of plastic with a strip of rubber cemented on top, so you install the new one right on top of the stock pedal. FYI, you need to bend the new gas pedal a bit to match the stock gas pedal before it will install properly (I put a piece of rubber on each end to protect the pedal and then I used a pair of vice-grips on each end so I could slowly bend the pedal. It was pretty easy), and be careful where you drill on all the pedals so you don't drill into the back parts that hold the pedals, because then you may not be able to fit a nut around the bolt/screw. You'll know what I mean when you take the rubbers off. It's an easy install if you're good with your hands and basic tools. Here's the link if anyone wants it. They have both MT (Manual) and AT (Auto). Specify in a message to the seller, during the purchase, if you want the "TRD" on them or not. https://www.aliexpress.com/item/1005...55d01802VU7lDQ
gizmokat
Scion tC 1G ICE & Interior
04-05-2007 04:29 PM
