Replacing tC shift knob
I've been looking into getting a shift **** that doesn't feel so cheap for my new tC but I haven't really seen anyone replace the stock shift ****. There are usually pictures of people installing the TWM short shifter with their shift **** and as I understand it, the reverse on that is different than stock. Before shelling out $60+ bucks on a shift **** I wanted to know if anybody had attempted to replace the stock shift **** and how it integrates with the pull for the reverse.
I was looking at getting something along the lines of the TRD shift ****, or even the TRD one if I can find a 6-speed one.
![Name: trdknob.jpg
Size: 23.8 KB](https://www.scionlife.com/forums/attachments/scion-tc-2g-ice-interior-1828/61762d1501348068-replacing-tc-shift-knob-trdknob.jpg)
1stOne, donsun and I have all replaced our shift ***** with the TWM M1 Abrams Shift ****. I know some others on here have mentioned having different *****, but I don't remember who.
To answer what I think your questions are:
- RL on the TWM short shifter is is smaller than the stock RL, meaning anything that fits the stock RL will fit the TWM RL.
- You should be able to get just about any shift **** that says it works with a RL. Shift ***** just screw on, so any **** that will clear the RL will be fine.
hey guys,
I got a custom **** done from WClathewerks. He started off doing subies and went from there. Ill take a picture of mine later but this is his site:
http://www.lathewerks.com/shop/
Hes actually a buddy of mine from college and has been doing this since about 2006 i believe. We used my car for the test fitment and everything and it works well. Its pretty cool because he actually does this using a lathe and none of it is CNC and is done by hand.
I installed a B&M chrome plated aluminum T-handle shifter on mine. I found a 12mm inner diameter collar in black oxide at work that took up the space inbetween the reverse pull collar thingy. The handle fits nicely with no needed threaded inserts. Drastically improved shifting. Wish I had done it sooner. Only downside is you can see the white plastic guie inside the reverse pull. A black sharpie took care of that. Looks pretty clean surprisingly. I am not a fan of using markers normally, but I did not want to take apart the reverse pull. If you chose to dissassemble the reverse pull, you can die the white nylon guide black with Rit dye from the grocery store. It is located in the laundry detergent sections usually. Works extremly well on plastics. Very commonly used on R/C plastic components. No pics yet but will take one later on monday if anyone is interested. I personally do not like the feel of round shift ***** at all. The B&M T handle is very comfortable and the wife even commented on how much better the shifter worked.
That does look good!
@ MightyP...Thanks for the reassurance. I was afraid of breaking something and was pressed for time. Does the white guide slip off? I saw what looks like a metal spring or retainer under it. Any tricks? Sorry for the hijack, but i think this will help more than me.
Thanks bud. Now I need to decide between silver or black paints/ dyes on the parts between shift **** and reverse pull.
Hey djsanchez, is it the pic. or is the distance between the top of shift **** and reverse pull that far apart? It looks like it would not feel natural when engaging reverse.
Can you guys get a tad more specific on the replacement of the OEM shift ****? Is this just a typical counter-clockwise removal, then additional steps to swap out the Reverse Lever (RL?).
Also, the threading is standard Scion? So for example, the TRD leather ball **** would/should fit...
use this link for reference. it's really easy.
http://www.twmperformance.com/manual...ion-manual.pdf
Thanks for the linky, alas the short (ball) TRD **** does not work with our 2011 tCs, just put it on and when it is snug the RL won't move... which has its downsides.
Guess I may have to put it back on the xB... *sniff*
I'm in contact with WC Lathe Werks right now to get one of their Copolymer ***** made. Looks like damn fine work over there. Not cheap, but then...we have limited options right now.
![](http://i10.photobucket.com/albums/a143/originalbello/trdknob.jpg)
I have this shift **** and love it. The fit-n-finish is just wonderful.
@ Nick
It actually fits nice. I like to sit a little further back so that my knees are not sitting on top of the dash while Im trying to drive. This **** gives me just the right amount of length so that I can sit comfy and still Shift without stretching to reach the **** or gears.
