2011+ Scion tC Bulb Sizes
2011-2013 Scion tC Bulb Sizes:
Low beam headlights: | H11
High beam headlights: | 9005
Fog lights: | H11
Brake lights: | 7443 CK
Front turn signals: | 7440
Rear turn signals: | 7440
Back up light(s): | 7440
License plate: | 194/168
Front side markers: | 2827
Map light (front): | 194/168
Dome light (rear): | DE3022
Trunk: | DE3022
2014+ Scion tC Bulb Sizes:
Low beam headlights: | 9012/9006
High beam headlights: | 9012/9006
Fog lights: | H11
Brake lights: | 194/168
Front turn signals: | 1156NA
Trunk: | DE3022
Fog lights: | H11
Trunk: | DE3022
Fog lights: | H11
Trunk: | DE3022
http://stores.mengmotorsports.com/-s...led/Detail.bok
Will these fit in the tC2 license plate light? I know on one website it said 194/168, are they the same?
__________
__________
well i went for these ones.
http://www.v-leds.com/Exterior-LED/C...-p4481133.html
a few bucks cheaper. hope they do the same thing.
1 - Are the signal/turn lights the 175's as well? It kind of looks like your answer was left blank on that one.
2 - How about the brake lights? Able to convert those to LED?
3 - What size is the reverse light(s)?
4 - I do not want ANY standard bulbs in my car. I want ALL to be LED/HID. Is this possible?
5 - Thanks.
I changed all the dome lights, as well as the trunk light in my car to LED, after a bunch of trial and error i got the right sized LEDs to fit. AND TO ALL OF YOUR BENEFITS :D!!! I'll write what i have written on the invoice i got, and if you have trouble finding the right ones i can go to the website and circle the exact ones i got, but i have no time at the moment D: (got all my bulbs from superbrightleds.com)
For the front dome lights, i put the
- WLED-x6: 6 LED Wedge Base Buld-WLED-CW6: Cool White
^--- two of these cause the front dome has two bulbs
the rear dome light i put the
- 3022-x9: 9 LED Festoon Bulb-3022-CW94: Cool White
^--- one of these cause its a double ended wedge bulb thing. it has 9 bulbs in a little square thing. amazingly it fits perfectly in the housing.
the trunk light used
- 3022-x4: 4 LED Festoon Bulb-3022-CW4
^--- this one fits snuggly in the trunk housing, but it makes the switch alittle hard to press...
License Plate Bulbs used
- WLED-x6: 6 LED Wedge Base Bulb-WLED-NW6: Natural White
^----- Same as the front dome lights, just used the "Pure white" instead, it looks nice o:
Reverse Light used
- 744x-xHP3: 744x series 3-HP LED Wedge bulb - 7440-WHP3: Cool White
^----- This was a 7440 bulb, the hardest part is taking out the old bulb, mine fell into the frame of the car ._. but it looks good, i didnt see pure white, there was only this white (It's much whiter than the same cool white color used in the domes), a yellow, and a red.
If you noticed, the trunk light and the rear dome basically have the same size bulbs. The 9 bulb LED would not fit in the trunk because the housing is too narrow. And the 4 bulb would be too dull to be in the rear dome light.
Sorry if its worded weird, i woke up at 5AM to write a paper and then had the good idea to post this because i got an email from the forum, saying someone replied to this post xD
GOOD DAY!!
EDIT: If i can get around to it, i'll post a picture of each bulb in each housing
EDIT 2: The bulbs from this site are cheap in price, so im certain a more expensive bulb will give a more brilliant color, etc. But for my first LED swap, i think its fine. Don't get me wrong, these bulbs are great, but i just know there's always more expensive and better quality around. the same for way theres a better alternative to everything else :D
Reverse Light used
GOOD DAY!!
Thanks, but yeah, i wish a write up was around when i bought them, i ended up wasting like $8 on bulbs that didnt fit!
And i would really like to see the brank, reverse, signal, parkers... Cause those are all i have left for the easy bulbs to swap D:
Definitely waiting to hear about the best LED swap for brake, reverse, signal and parking lights!
No problem! it's a pleasure to finally do something useful xD.. But no, i dont have the license plate swapped to LED..
I too am waiting on someone to give a list of the bulbs for all those other great places.
Also, the switch being harder to press, why is that? Hopefully, it shouldn't be too big of a deal, since ultimately, the trunk light is controlled by the hatch opening and closing right? Most people would leave the switch on, I would imagine.
