2011-____ [ANT20]
Foot Patrol SuperWhite Build..UPDATE! Pretty Turbo, Underglow
Old 04-13-2012, 06:33 PM
  #501
zaksturbo's Avatar
what are you dropped on? i looked and didnt see it, i prolly looked over where it said.
zaksturbo is offline
Old 04-13-2012, 06:54 PM
  #502
DaYUUM/Scion Evolution
KidJustin's Avatar
std r1...its on the first page bud
KidJustin is offline
Old 04-13-2012, 07:07 PM
  #503
zaksturbo's Avatar
Who sells the std coilovers? Can't seem to find them
Old 04-14-2012, 03:01 AM
  #504
jtk2's Avatar
Yes everything installed is on first page.
Everyone had just been going to theyre site and calling them. Standardsuspension.com or something like that.
jtk2 is offline
Old 04-17-2012, 02:03 AM
  #505
BossNguyen's Avatar
Do you have any problems with rubbing or anything?
BossNguyen is offline
Old 04-17-2012, 03:09 PM
  #506
jtk2's Avatar
In the front there is a little rub. Like when I'm going fast and hit a big dip or something but not to bad. Just rubs on the plastics is all. And the rears don't rub at all and that's due to a very good fender roll job.
jtk2 is offline
Old 04-17-2012, 05:04 PM
  #507
ProjectTC2's Avatar
Word on the street is you were looking for the LED in the mirror controls too. Did you ever figure out what size it is or how to disconnect / connect a new one?
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 207KB.
That's the LED ^
ProjectTC2 is offline
Old 04-17-2012, 05:58 PM
  #508
jtk2's Avatar
I was. I believe it was mightyp that actually told me. And I want to say it was a 5mm flat? I could never find one so I tried a 5mm led like the 3mm in our ac controls. But in the process of desoldering that led I messed it up. So I just added a led strip in there.. But on the back. Find the solder points. Desolder and solder a new one back in. Or just take that out and add an led strip in there.
jtk2 is offline
Old 04-17-2012, 09:07 PM
  #509
BossNguyen's Avatar
So i'm planing to also get std r1 coilovers, I don't want my tires to be rubbing, I don't want to be having to pay for tires every couple of months, since there is no camber kit out(correct me if I'm wrong), how low do you think i can go without rubbing? I don't drive very fast at all and I always pay attention to pot holes and what not.
Old 04-17-2012, 09:30 PM
  #510
ashtc2's Avatar
Are standard suspension coilovers designed for track use or for stance purposes (like ksports).
ashtc2 is offline
Old 04-17-2012, 10:30 PM
  #511
KidJustin's Avatar
standard has two sets...the R1 and the R3
i believe R1 = street and R3 = track...Mamba should know better
Old 04-18-2012, 06:14 AM
  #512
ashtc2's Avatar
mamba is staggered so theres no point of having the high end ones if the car is going to oversteer like crazy. and jtk2 is stretched and has rims so wide it cant be good for the track. I want coils that are good for tracking with the proper setup
ashtc2 is offline
Old 04-18-2012, 04:04 PM
  #513
jtk2's Avatar
There is a camber kit for the front that helps out a lot. But I'm dropped about 2.5 in the front with little rub and that's only because of my setup. I've never had the coil overs on the stock wheels so I cant say much. But you still should be able to go about 2 inches without any rubbing.
Justin is correct. R1=street and R3=track
The R3 would be a good choice for you then. Just because we decided to just use them for stance as nothing to do with them not being a good quality coilover which they are.
jtk2 is offline
Old 04-18-2012, 04:41 PM
  #514
BossNguyen's Avatar
What about the rear wheels, do they tent to rub less than the fronts? Also when you lower your car are you supposed to lower all the same length?
Old 04-18-2012, 10:57 PM
  #515
jtk2's Avatar
Only the two front have to be the same length and the two backs have to be the same.
jtk2 is offline
Old 04-19-2012, 03:21 AM
  #516
2tCornot2tC's Avatar
staggered = wide in the back = understeer like crazy! Not oversteer...
2tCornot2tC is offline
Old 04-19-2012, 03:23 AM
  #517
ashtc2's Avatar
whoops. thanks for the correction.
ashtc2 is offline
Old 04-23-2012, 04:54 PM
  #518
jtk2's Avatar
another large update coming soon!! most likely in a couple weeks. so excited!!
jtk2 is offline
Old 04-24-2012, 05:02 AM
  #519
devanb3's Avatar
dont leave us like this what is it a hint some sort of guessing game
devanb3 is offline
Old 04-24-2012, 06:03 AM
  #520
KidJustin's Avatar
doubt its wheels...he did that more than once already...
people are usually set after going coil...
lip kit? i wouldnt put money on it....sound system? probably not....
so its probably performance....intake is check and headers.... exhaust not "large" enough maybe a bbk? maybe, but i'm going with boosted auto set up (turbo)
Quick Reply: Foot Patrol SuperWhite Build..UPDATE! Pretty Turbo, Underglow
