2011-____ [ANT20]
HID Flickering Driving Over Bumps?
Old 09-12-2012 | 12:23 PM
ribjub's Avatar
Question HID Flickering Driving Over Bumps?
So, I just installed a 6000K 55W HID kit from DDM. The lights work well and turn on with no issue, but there's a minor problem. It seems that whenever I'm driving and hit a bump in the road, the passenger side light will flicker for a bit, but then it stops (as long as the road gets smooth). I thought it may be the ballast that's a little loose under the hood, but both the bulb and ballast are secured. Anyone know what the problem might be?
Old 09-12-2012 | 02:19 PM
Jon's Avatar
Jon
Moderator
Moderator
Made in China.
Old 09-12-2012 | 02:31 PM
ProjectTC2's Avatar
Originally Posted by Jon
Made in China.
Like ^
Old 09-12-2012 | 06:02 PM
disaster06's Avatar
I had the same issue but mine would always flicker. I picked up some from DDM Tuning and haven't had a problem since.
Old 09-12-2012 | 06:28 PM
user 7208230's Avatar
Huh? He's saying he's having problems with DDM.
Just get them to warranty the set, they're pretty good with that, and get a 35W set, 55W is unnecessary and can be problematic.
Old 09-13-2012 | 06:06 AM
disaster06's Avatar
Woops, missed that. Mine were cheap eBay lights, then I got the DDM's and have not had issues
Old 09-13-2012 | 01:21 PM
ribjub's Avatar
It's all good. Found out I cracked the bulb during install. Was trying to seat the light in the housing without knowing I had to cut the plastic ring off the bottom of the light. So, I'm guessing trying to force the light in cracked the bulb right at the base
Old 09-13-2012 | 02:24 PM
StatuSCheckA's Avatar
Thats reassuring dude. Thanks. I'm not sure what you had to cut tho, can you elaborate?
I had HID Extra and after week 1 the driver side would always slightly move side to side (very slightly, very annoying) aside from the ballast blowing out a few weeks later.
I am now going to try DDM before I go to an expensive kit.
$30 with good reviews was impossible to resist.
Old 09-13-2012 | 05:14 PM
ribjub's Avatar
From DDM, the base of each bulb has a clear plastic ring around it. Before you install the bulbs, you need to cut the plastic ring off and push the orange rubber seal down on the base. The passenger side bulb was the first one I tried installing, without knowing that I needed to cut that ring off. So I kept trying to force the bulb into the housing, and I'm guessing that's where I cracked the bulb.
Other than that, no complaints with the DDM HID kit. The lights are nice and bright, and the colour is very pure
Old 09-14-2012 | 04:27 PM
arrehenius's Avatar
I had the exact same issue with my HID's from MengMotorsports. The instructions didn't mention that the black o-ring had to be removed...
Jammed one HID in but the other wouldn't go in. Had to find out by the helpful people on this forum. Sucks that the bulb cracked for you though
Good to hear that you like the lights though!
S7ephavs
03-22-2015 12:09 PM
GoodVibes
03-10-2015 04:29 AM
clickclickw00t
02-18-2015 08:57 PM
tc_Jake
12-31-2014 01:45 AM
TheRedBox
10-08-2003 04:25 PM
Quick Reply: HID Flickering Driving Over Bumps?
