Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Alignment Specs
Old 12-28-2012 | 03:08 AM
russiankid's Avatar
I just went in for an alignment and my rear camber was at -2.5 on both side. What surprised me the most is front and rear toe were -.3x range. I ended up setting the front to -.12 and rear to -.10. Car handles a lot better now, i am also running Tein S-techs's.
Old 12-28-2012 | 06:58 PM
2tCornot2tC's Avatar
Cool...you lucked out! But still more than I like...
Old 01-07-2013 | 11:17 PM
russiankid's Avatar
I went ahead and redid the alignment. I set the front toe to be .05 on both sides, that way it zeros on when car is in motion. I set the rear to .07 on both sides so it will zero out when I have weight in the back. So far I am happy with the results.
And as for the rear camber, I wish I could make it less but have to roll with what I have.
Old 01-08-2013 | 02:48 AM
Then you did it wrong. On a FWD car, you need negative toe (toe out) for it to zero out in motion. I set mine to zero on static and then get a slight toe in in-motion...
I think I set my rears to .01 toe in so they zero out in-motion... That sounds like you've set a whole bunch of toe in front and rear. Keep us posted on your mileage and tire ware...they should both be quite high now.
Old 01-10-2013 | 03:59 AM
russiankid's Avatar
Even with my .05 toe up front and while in motion I am still in the specified range from Toyota(total toe). My mileage has not increased, it has always been 24mpg around town and 31-35mpg highway. Made a trip back to school with the new setup and still same mileage.
Old 01-10-2013 | 04:11 AM
If your alignment was “bad” (at maximum allowable in the wrong direction) from the factory and it is bad now, your mileage will have always been bad… we don’t know your alignment setting before your current settings to make a before-and-after analysis. Just asking to keep an eye out for tire ware patterns…front-to-rear, side-to-side.
Old 01-10-2013 | 04:34 PM
russiankid's Avatar
I don't know what my alignment was from factory, I know after lowering I had about -.35 toe all the way around. That really showed in my tire wear. The new alignment is within specifications. I will definitely keep an eye on the tire wear.
Sgtfluffy16
Regional - Northeast
07-28-2021 11:32 PM
Sgtfluffy16
09-30-2015 02:42 PM
vi3tb0i09
09-23-2015 09:32 PM
Subaru86
09-10-2015 09:33 AM
