Eibach and H&R springs availible
Definitely seems like they're ripping me off. I might try to find someone in the area who's able to help me install them, then I can buy the springs off of TRDsparks and save a ton of money on installation. Still wondering where biglilsteve got his $399 for part+installation.
TRD - LOWERING SPRINGS
$399.00
TRD lowering springs lower the vehicle's center of gravity by approximately one inch, enhancing the vehicle's on-road performance through quicker turn-in, enhanced steering response and improved cornering ability. Featuring TRD's durable bold red powder coat finish for superior corrosion resistance, the lowering springs have been rigorously tested and engineered to help ensure against rattles, clunking or rubbing.
Installed MSRP is the Manufacturer's Suggested Retail Price for accessories installed by the manufacturer. Actual prices for dealer installed accessories may vary. Please see your local Scion dealer for pricing. Prices and product availability are subject to change without notice.
I had mine installed even while shooting a video in 2 hours with no power tools and jack stands for demonstrative purposes. No reason a shop should charge more then two hours for this with wall mounted spring compressors and power tools. I've worked at dealers before (Toyota included). Not all of them are trustworthy and will try and rip you off. Very few that are really legit anymore which is sad to say.
ninerbud, thanks a ton for finding that on the website, i forwarded that to the dealership and they are willing to do $399 for the part + install. and this is from the same dealership that quoted me $700 for install alone. can't believe this is how dealerships treat their customers and try to rip them off big time... I'll have my TRD's installed in a couple of weeks
Hello to all, this is my first time to post in the forums (been a lurker most if the time)
To stay on topic: I got my tc few weeks ago, and I went back to the dealer to ask for a quote on how much to install springs. The guy said we are looking at around 10 hours of work and it'll cost me around 1000 without parts. I just can't believe how much lies goes thru that dealership!
I'm sure glad I read this thread.
On the side note: maybe I couldve asked for spring install before I bought the car, then it wouldve cost me just 399. But I guess its too late now.
Welcome!
And yeah I can't believe how high some dealers are trying to quote!
I have personally dealt with this issue when having other scion accessories installed. As soon as you quote the site, they drop to their knees
Why do you think that? Your car is still in the same condition as they would have gotten it to install at the dealer when new...
An other thing...the car must be within spec if the dealer does it. There is no way that the alignment can be right after a spring install. I would let the dealer install the spring and then come back a few days later complaining that the car wanders now and does not feel right. They MUST then check the allignment...if it is out, they are required make it within spec. I would then drive it for a few months (but make sure it is still within their within their waranty time) and take it back comlaining of the same symptoms...they will re-check it to the same OEM specs...
Look at that! An install and 2 alignments for $399!
Well...that is what I would do...- don't know about you guys though.
This is step 9 of the Toyota installation istructions for installing the PTR11-21100 TRD lowering springs;
9. Alignment
So it does not allow them to go out of spec once the springs are installed and is includded in the installation cost...that is how I read it...covered under waranty...at any dealer.
9. Alignment
Alignment should not be necessary after installing the TRD lowering springs. However, checking for correct measurements and adjusting to the specs. below will provide optimal performance from your SCION tC.
Front:
Total Toe = 1.0 +/-2.0 mm (0.04 +/-0.08 in.)
Camber = -0°13' +/-45' (-0.22° +/-0.75°)
Rear:
Total Toe = 3 +/-2 mm (0.12 +/-0.08 in.)
Camber = -2°0' +/-30' (-2.00°+/-0.50°)(Modified by TRD USA) Note: camber is not adjustable
Front:
Rear:
Alignments are like brakes, they are considered regular maintenance items. Unless you hit something or in this case, change a suspension component, you shouldn't need an alignment at least until suspension components start wearing out.
To bring this thread a bit back on topic:
Was looking around for springs again and it seems that eibach did their research on the tC's sportline springs:
http://performance-suspension.eibach...cion_tc_2011__
I'm pretty tempted to get these over the TRD since it drops the rear more
anyone know when trd is releasing shocks for the tC2?
