Help Wheel fitment varrstoen es 221
hi guys , i'm buying the varrstoen es 221 18 x 9.5 +34 wheel and i want to know if the stock wheel will fit on (225-45r18 ) ? and my car is drop got half inch clearance in front and 1 inch in rear.
ty lot
ty lot
I'm assuming you mean stock 'tires' not stock wheel. Here's a visual for reference, but it'll be a stretch.... pun intended.
Hopefully someone with experience with this wide a wheel can comment if a 2" stretch would work, but I'm going to suggest you look at a wheel that is less wide.
By the way the picture is a cross section of the tire as if you are looking down on the car, black lines are the wheel and hub, blue is the tire, and the red line is the fender on the right.
Go with 225/40/18.. I have them right now on my 18x9.. nice stretch and fills up the fender gaps very nicely
I tried 215/35/18 before.. and the stretch is nice but our scion tc fenders is HUGE so it will ugly..
I would just buy used tires.. you will be in negative camber and tires will wear out quicker then before.
I currently have Michillin pilot sports on my rear and Bridgestone potenza run flats in the front.
If i were you.. stay away from run flats as they are noisy. Go with dunlop if you want a nice all season w/ performance.
