Stock/TRD Wheel Fitment/Weights 2tC
Old 10-04-2010 | 06:08 PM
jkchang626's Avatar
Default Stock/TRD Wheel Fitment/Weights 2tC
We always need the stock fitment information to get a jumping off point for wheel fitments. I supposed I'll start it off
All info is based on USDM 2011 tC.
PCD: 5 x 114.3 (5 x 4.5)
This is now the same as the 2nd generation xB (and just about all current Toyota cars except the Yaris, Corolla, Prius, and the trucks/suvs of course).
Stock Wheel
Description: 7 Dual-Spoke Wheel
Size: 18 x 7.5J
Offset: (Checking)
Weight: 26.7 lbs Official
Tire Size: 225/45R18
TRD Wheel Option
Description: 7-Spoke Wheel, Gloss Graphite Silver finish
Size: 19 x 8.0J
Offset: +35
Weight: 24.1 lbs Official
Tire Size: 235/35R19
Tested
Five Axis Design R5:F
Description: 5-spoke alloy wheel
Size: 19 x 8.5J
Offset: +30
Weight: ???
Tire Size: 225/35R19
Suspension: Tein Coilovers (unconfirmed model, likely Super Street)
Notes: Clears without issue. Rear can use a spacer to flush out. 9.5 +35 fits rear if staggered look is desired.
We'll start doing some test fitments once we have more stock. Til then, this should be a good starting point. I'll update with more info (and pictures) once available.
Old 10-06-2010 | 05:37 AM
MrBurrito's Avatar
stock wheel offset is about +39
Old 10-06-2010 | 06:08 AM
peeweezio's Avatar
Stock Wheels from the Manual Transmission w/Yokohama Tires weighed 52 lbs mounted when we took them off and weighed them. We also put the 19x9.5 +40 offset Ark Design wheels from my xB on it and they fit perfect.... no rub anywhere, but keep in mind there was no drop. It looks like you may be able to fit a 1o inch wheels with 265 or 275 tires.. we shall see next week when the HRE wheels come in.
Old 10-06-2010 | 01:51 PM
1stOne's Avatar
I've eye balled a few fitments as well. A 9.5" or 10" should fit with some camber and a 255-275 should also clear. The rear seems to be the issue making 255 seem more feasable.
Let me know when you get fitments on the tC.
Old 10-18-2010 | 12:16 AM
salty991's Avatar
whats the bolt pattern on the new one??? still the same as first gen??
Old 10-19-2010 | 01:23 AM
jkchang626's Avatar
The first gen is 5x100.
The second gen is 5x114.3 (5x4.5) which is the same as just about every Toyota 5-lug (except xD, Corolla, trucks). So it's the same as the xB2.
Old 10-19-2010 | 02:15 AM
oneshotted's Avatar
I just bought a 2011 tC and i'm looking to get some wheels for Winter season.
Does anyone know what is the Center bore diameter ?
Can you confirm that the offset is +39 on the 18inches wheels ?
Toyota dealer does not have any listing yet for replacement wheels on the 2011... They said they currently use RAV4 17" wheels for winter...
I'm looking to get 16 inches wheels for Winter, any advice on which Offset should i get?
Thanks!
Old 10-19-2010 | 04:56 AM
jkchang626's Avatar
Thanks!
I'll take a look once I get into work tomorrow. I think 17" may be the smallest that will fit since the brakes are relatively large.
Old 10-19-2010 | 05:34 AM
oneshotted's Avatar
Thanks for the reply.
I would really appreciate the info.
Seems like this car is not going to be cheap on tire!
Old 10-27-2010 | 01:36 AM
Bertmagik's Avatar
cheapest tires ive found for stock 1st gen 17s that were still not quite garbage were around 130 a piece mounted and balanced
Old 10-27-2010 | 03:42 AM
1stOne's Avatar
Car comes with a 16" spare, so that is the smallest wheel that will fit.
Old 10-28-2010 | 08:49 PM
jkchang626's Avatar
Touche~ Never thought of using logic LOL.
Front fitment of 19x8.5 with 30 offset worked nicely. Did a staggered (obviously for show only) 9.5 +35 in the rear without issue as well.
Old 11-02-2010 | 06:13 PM
JDMJim's Avatar
^^^ why does staggered have to be show only?
edit: that white tC looks awesome
Old 11-08-2010 | 07:52 AM
Papa_Bear's Avatar
Do you guys think I can run an 18x10 grid with a 15 offset and 245s? Picking mine up Friday. Paperwork signed today I will be rolling my fenders and some 1.5 negative camber front and rear. Or should I just stick with a 9.5 on a 255?
Old 11-09-2010 | 01:01 AM
excaka's Avatar
i want to get some new rims for the tc2, but want to keep the stock tires. whats the official offset?
Old 11-15-2010 | 04:58 PM
2tCornot2tC's Avatar
The stock wheels say 39 on them...I had them off this weekend to install mud guards.
Old 01-25-2011 | 06:57 PM
The new TRD catalog is out
http://www.toyotaracing.com/trd/cata...RD_Catalog.pdf
There seems to be two wheels for the 2011 tC...
a low pressure cast wheel PTR56-21110
and a forged wheel PTR56-21100
Are they the same width? Can anybody verify this?
What are the weight diferences? They are both a 7 spoke design...
Old 01-25-2011 | 10:44 PM
Scion Canada's Avatar
SCION CORP
There is only one wheel for tC... PTR56-21110. It is 19" x 8".
Each wheel is 24.1 lbs, which IIRC is about 2.5 lbs lighter than the factory 18"s.
EDIT: Just re-read the first post. Info is correct.
Old 01-26-2011 | 02:05 AM
MightyP's Avatar
Posting here for my own future reference...
Old 02-28-2011 | 07:54 PM
Lexus F-Sport
Description: Full-Face Forged Alloy Wheel, 10-Spoke
P/N: PTR45-30103
Size: 19" x 9"
Offset: 40-mm
Weight: 22.71-lbs Measured
Tire Size: 255/35ZR19
http://www.lextuners.com/f-sport-ful...-x-9-rear.html
Just for the picture - not where I bought them from.
