cowl removal
Old 03-27-2005 | 07:02 PM
jct's Avatar
jct
Default cowl removal
when tuesday rolls around and i get home from work, the ups man brought me my dc strut bar
and i'm gonna install it that night too
so how do i go about taking my cowl off (windshild wiper assy.) apart???
pictures would be nice if you have any...
Old 03-29-2005 | 11:52 AM
jct's Avatar
jct
any body know yet???
Old 03-29-2005 | 03:34 PM
BCS's Avatar
BCS
I don't have any pictures...but here are the basic steps.
First, remove the wiper blades. The cap comes off, then there is a nut you have to remove. I believe it's a 14mm.
Second, remove the plastic parts. There is a seal that you kinda have to move, and then the wole plastic part comes off. There are two pieces too it. Remember how they look together, it'll just make it easier to put back in.
Next, you'll see the bolts that attach the cowl to the firewall. I think these were 10mm, but i can't remember. There are like....4 or 5 of them. Remove these, and the cowl will come off. I think there was something that the cowl has to slide over, but it's pretty simple to remove.
The last itme i did this was over a year ago, but those are the basic steps to removing it.
Good luck.
Old 03-29-2005 | 03:57 PM
dgHotLava's Avatar
moved...
Old 03-29-2005 | 04:55 PM
M-Flo's Avatar
There's no need to remove it...
Just lift the front end of your car up, remove the strut nuts, and push down on the tires. You'll have enough clearance to mount the strut bar without taking out the assembly.
Old 03-30-2005 | 12:22 AM
jct's Avatar
jct
wellllllllllllll....
i removed the cowl, and OMG that was cake walk!!!
that is way way WAY much easier then doing it the hardway!!!
remove the strut bolts and i didn't have to use a open/box wrench either :D and o just torqued 'em to spec haha not many ppl do that with the cowl in place
the only think i didn't care much adjusting the wipers back into the right place!.!.!.
Sgtfluffy16
Regional - Northeast
07-28-2021 11:32 PM
steeze69
05-24-2021 03:57 AM
Sgtfluffy16
09-30-2015 02:42 PM
jbernard
09-03-2015 01:03 AM
