2004-2006.5 [NCP61]
2008 xb rear disk brakes on xa
Old 01-07-2008 | 04:23 PM
xa007xa's Avatar
Default 2008 xb rear disk brakes on xa
Has anyone tried to convert 2008 xb rear disks for xa?
Old 01-09-2008 | 04:51 PM
trdsparks's Avatar
I highly doubt that is possible. They are completely different chassis and suspension setups.
Old 01-09-2008 | 05:16 PM
xa007xa's Avatar
yup. so is the 1988 corolla gts and the conversion was done with a simple caliper mounting bracket being custom fabbed. difference with the 08 xb is that it still has the same torsion beam suspension as the xa. i haven't checked to see if 08 xb has 4 or 5 lug rotors, but if they are 4 lug i would assume that it might be easier to accomplish than with the 88 corolla approach. i believe that you need to shave off 1/5" from the inner diameter of the corolla rotor to fit on the hub. also be nice to use new toyota calipers rather than remanufactured ones from the 88 corolla. but at this point and with all the custom fab work needed to mount the calipers, might as well go with a set of brembo's or other calipers.....hmmm..... soon. since im not turboed yet, i have no need for the added braking yet....
Old 01-09-2008 | 06:54 PM
jct's Avatar
jct
they are 5x114
bostondaniel
Scion xD Suspension & Handling
15
09-12-2020 04:16 PM
toyotaisme
01-10-2015 11:24 PM
Slopoke21m
54
04-23-2007 01:25 AM
mrbadass03
11-10-2003 09:08 PM
PushyTop
12
10-26-2003 07:10 AM
Quick Reply: 2008 xb rear disk brakes on xa
