2004-2006.5 [NCP61]
30k maintenance
Old 03-06-2009 | 02:31 AM
carlitoselcool1's Avatar
Default 30k maintenance
what are we supposed to check, replace, for 30k maintenance thanks
Old 03-06-2009 | 07:02 AM
mb2008's Avatar
It's in the manual. Get better spark plugs, don't use the cheap ones from Toyota. Oil, filter, spark plugs, rotate tires and you're good.
Old 03-07-2009 | 12:38 AM
thnaks what about an ac filter?
Old 03-07-2009 | 02:39 AM
jct's Avatar
jct
you can make your own for the cabin filter
Old 03-08-2009 | 06:45 PM
Where in the cabin Is the ac filter and what do u mean by making my own
Old 03-08-2009 | 06:57 PM
ein311's Avatar
Cabin filter is behind the glove box. There's a little tray you slide out.
Follow the tech article here: https://www.scionlife.com/forums/viewtopic.php?t=109592
It shows how to make your own.
Old 03-16-2009 | 05:23 AM
SlowScion4L's Avatar
Actually, the best spark plug for the car you can get are the cheap ones from Toyota. The dual ground prongs are used for the swirl spark ignition that the scion engine uses. It is actually one of the few engines that benefits from a multi prong plug.
Old 03-16-2009 | 06:34 AM
Coolwaterz's Avatar
just get NGK iridiums...
toyota uses delso iridiums so they should last 60k miles but my dads sparks were bad way before 60k miles...
pro710
12-27-2023 03:34 PM
Threequalseven
08-26-2015 04:24 PM
michaelclld
07-16-2015 04:32 AM
stenger
07-15-2015 01:03 AM
Quick Reply: 30k maintenance
