2004-2006.5 [NCP61]
anyone else check engine light
Old 03-14-2006 | 04:35 AM
dexter_5000's Avatar
Default anyone else check engine light
it turns out my check engine light was on for a camshaft postion sensor. they said it's the 2nd time they've seen this on the xa model. has anyone one else had this same issue just curious.
Old 03-14-2006 | 12:47 PM
TheCor's Avatar
my check engine light just came on saturday, i had it checked yesterday and it wasnt for the camshaft, but for a charcoal filter in my emissions system, they have no idea why it went, oh well
Old 03-14-2006 | 01:37 PM
ASC's Avatar
ASC
I just had my CKP (CRANKshaft position) sensor replaced about two weeks ago. The code was P0335. I thought it was the cause of my hard starting problems, but it was not. Every once in a while, I find that I need to let the engine crank, or depress the gas pedal to allow more air into the engine.
Old 03-14-2006 | 08:04 PM
DrewJM's Avatar
My check engine light has been on since i bought the car in December. Ive had mine in several times, once to modify the charcoal canister- fixed it for a week or so, now im on my way back, apparently they have a new part to replace it with (I was told the 2006 xa's have different charcoal canisters than the previous xa's, the new ones are getting moisture inside them, but its not a recall yet) oh well
Old 03-14-2006 | 09:40 PM
update with my car it was the vvt-i acutuator which meant the tech had to pull the camshaft out to change it.
Old 03-15-2006 | 04:33 PM
TheCor's Avatar
good to know! im just waiting for the part to come in now
Old 04-08-2006 | 09:52 PM
diggity's Avatar
Mine came on after about 6 months. It was the morning after a heavy rain, nothing else unusual, and it still drove fine. Was planning to have it checked this weekend when, voila, the light went off.
Old 04-08-2006 | 10:33 PM
GrantR's Avatar
My "maintance required" light just started going this week. It blinks at me for 10 seconds when I start the car then goes away. Is this the same thing as the check engine light, but with a different name? Is it perhaps a built in "don't forget to do your first oil change" light? (even though I just did an oil change myself 2 weeks ago)
Is there any good easy way to identify why the light is on other than going to a dealer? On my MR2 I'd jumper some diagnostic pins in the engine bay then the check engine light would blink out it's code, which I could look up to see what the problem was.
Old 04-08-2006 | 10:43 PM
diggity bring yours in even though it shut off have it scanned under warranty and make sure they fix the problem.
GrantR the maint req light is just an oil change reminder light look in your manual or search on the forum to learn how to reset it. you can bring your car to autozone for a free obdII scan like i did. i brought it to the dealer since it was under warranty just to get there oppinon and have them fix it anyway. you can also purchase an obdII scanner but its kind of expensive.
Old 04-10-2006 | 12:54 AM
GrantR's Avatar
ah, thank you, dexter I shall go and RTFM
Old 04-14-2006 | 04:19 PM
Garzasgirlie's Avatar
my check kengine light also came on to remind me of the 1st oil change but not till it was about 1000 miles overdue...
Jordly221
02-13-2019 05:29 PM
Miqmiqmiq
04-16-2016 02:34 AM
daniinpitt
04-04-2015 08:07 PM
Bakoscion46x
01-19-2015 02:39 AM
AdmirN
01-05-2015 10:19 PM
Quick Reply: anyone else check engine light
