2004-2006.5 [NCP61]
Funny shift points on xA automatic trans?
Old 06-13-2005 | 06:03 PM
Doohickie's Avatar
Default Funny shift points on xA automatic trans?
In another thread, hnefrdo said
other than that, the only thing that still bugs me is the stubborn first to second gear shift. that's not so much a "problem" either, as it is more of a characteristic of the transmission than a defect. just wanted to give you a heads up on that one before you buy. just make sure you test drive.
I noticed this on my test drive. I may be buying an xA for my next car, and am interested in what people think of the high shift point on the auto. Is it annoying? Can you train yourself to modulate the accelerator to minimize it? Is it any different with stock vs. 17 inch wheels (I test drove the 17s but plan on getting stock)?
Old 06-13-2005 | 06:23 PM
Squishy's Avatar
it has an OD button. i think my xA shifts great and very smooth. Personally I like that 1st to second revs a bit high, makes it feel more peppy for an automatic. I've taken 2 trips over the mountain passes and have to say the xA has been great going up pass and keeping it at 80 is never an issue even on steep inclines.
It may have to downshift and rev higher, but it goes goes goes!!! I've had it 3 weeks now, with 1 mile on it at purchase. I've put 2000 because of these 500+ mile trips I've had to take and I couldn't be happier.
Old 06-13-2005 | 06:27 PM
Doohickie's Avatar
Maybe the OD was disengaged when I did my test drive. If that was the normal OD mode, it hung onto first for WAY to long. I'll have to try it again and compare OD vs. non-OD... and also (hopefull) with the stock wheels.
Old 06-13-2005 | 08:14 PM
matt_a's Avatar
Remember, it's also going to shift at a different point when it's "cold". Alot of newer cars with everything being computerized, seem to wind out 1st and 2nd gear longer untill things warm up. My Chevy Silverado used to do it all the time in the winter. My xA is 5-speed so I wouldn't know about it, but my wife's xB is auto and I noticed that it does it.
Old 06-13-2005 | 08:23 PM
oldmanatee's Avatar
Just take it easy for the 1st half mile til the light goes out and then you can go like stink!
Old 06-13-2005 | 09:23 PM
Doohickie's Avatar
When I noticed the funny shifting, it was well into the test drive- maybe 10 minutes or more. So maybe the OD wasn't engaged.
Old 06-13-2005 | 09:42 PM
xagirl's Avatar
If the overdrive was off, the light on the dash would go on. You'd have probably noticed it. I noticed on my xA (automatic) that it drove/shifted a lot smoother after 500 miles or so.
Old 06-13-2005 | 09:49 PM
mikochu's Avatar
hnefrdo was talking about the 5speed transmission. The 1st to 2nd shift on the 5speed can be notchy. I had the same problem when I first got my car. Now, it seems to be broken-in...
Old 06-13-2005 | 09:51 PM
Torydk87's Avatar
I like the way it shifts. The longer acceleration is great for merging onto the interstate.
Old 06-13-2005 | 10:28 PM
jct's Avatar
jct
you'll get use to it
Old 06-14-2005 | 12:04 AM
XaRS0888's Avatar
my xa felt alot smooth after 1000 or so miles. use the OD button helps in town driving as well.
Old 06-14-2005 | 02:14 AM
Doohickie's Avatar
Ah... my bad... I thought the hnefrdo was talking about an automatic. But it does linger longer in first (auto) than I would expect.
eric_m
52
01-17-2019 05:50 AM
mischman
01-14-2015 06:07 PM
Scionxa180
Scion xA Aero & Exterior
01-08-2015 08:33 PM
TheTripleC
01-04-2015 06:46 PM
KKWL
12-04-2014 07:12 PM
Quick Reply: Funny shift points on xA automatic trans?
