2004-2006.5 [NCP61]
Help with OBD Code
Old 10-06-2010 | 10:20 PM
FL21289's Avatar
Exclamation Help with OBD Code
The check engine light came up a few days ago; at first i ignored it and it went away, its been around 4 days and it has not come back. Today i connect my reader and code the code P0012.
Now i know what it means and all; http://www.obd-codes.com/p0012
But my question is what do i have to do to solve this issue? Does anyone know or they ever had this problem with the Scion XA before?
Any info will help.
Thanks,
Frank
Old 10-06-2010 | 11:56 PM
padillaXA's Avatar
i'd say it might need a new cam position sensor/solenoid, how is it idling? i had this code before along with several others like P0013 and i had to replace the camshaft position sensor. its right beside your alternator, check to see that its plugged in,or if its leaking any oil, also follow the wires and see if there damaged at all,maybe take it out and look at it. its only held in by one bolt, easy to remove just have to take off the alternator bracket first to get to it.
good luck
Old 10-07-2010 | 12:10 AM
FL21289's Avatar
good luck
Its a XA idle you can say; it vibrates a bit but it always has. I really can't tell the difference car is running fine. Wires and all are good and never been damaged. Its weird.
Old 10-07-2010 | 12:49 AM
padillaXA's Avatar
haha yea, its not the smoothest idle.
well the problem seems located to this part i just dont know were to go from here...
is the check engine light on right now? i really think its that part, cuz other than the CEL and random(but not constant) rough idle you cant tell the parts broken, but as soon as i put in the new part the idling came smooth and the light turned itself off. your call, the parts pretty cheap.
Old 10-07-2010 | 01:01 AM
FL21289's Avatar
Naw dude check engine light turned off so there is nothing now, but either way whats the part called and how much is it like in price???
Thanks again man.
Old 10-07-2010 | 01:39 AM
padillaXA's Avatar
na its cool, no problem. its the camshaft position actuator and the cheapest one i found was for 80bux after S&H.(this is the one i bought)
http://www.toyotapartszone.com/oem/t...330-21011.html
but vettereddie the moderator says he has some, don't know how much but i'd Imagen cheaper, you just have to PM him
Old 10-07-2010 | 02:09 AM
FL21289's Avatar
http://www.toyotapartszone.com/oem/toyota~valve~assy~camshaft~timing~oil~control~15330-21011.html
So this is pretty much the Camshaft Sensor correct?
Thanks a million bro!
Old 10-07-2010 | 03:08 AM
padillaXA's Avatar
its no problem!
from what i heard tho its not a sensor, it just adjusts the position of the cams to advance them or retard them. i miss typed and miss defined it in my first post, its not a sensor.
Old 10-07-2010 | 04:29 PM
FL21289's Avatar
its no problem!
Gotcha, thanks again man. Its funny i might need to make my Cams retarded
That_Kid_Ju
09-30-2015 11:05 PM
vi3tb0i09
09-23-2015 09:32 PM
wayneside
Regional - Southeast
09-23-2015 11:42 AM
wayneside
Regional - Pacific Northwest
09-23-2015 11:29 AM
Gigs
09-15-2015 04:54 AM
