Intake problem with my 05 XA need HELP FAST!!!
Hello, I have a problem on my 05 XA with my intake (I think) Well I got Bomz cold air intake for it and after I started my car and tried to rave it up, my RAVE limiter kicked in at 3RPM's so now it wont let me go pass that (driving too). It did fine with my old stock set up but not with this any ideas???
I took it to Shocks and they did CPU check and here what it told me
Engine Computer Codes
Trouble Codes:
P0101-Mass or Volume Air Flow Circuit Range/Performance Problem
P0103-Mass or Volume Air Flow Circuit High Input
P0113-Intake Air Temperature Circuit High Input
Pending Codes:
Freeze Codes:
Readiness Test
Engine Status Light.........ON
Misfire Monitor.................Completed
Fuel System Mon.............Completed
Comp. Component...........Completed
Catalyst Monitor .............Not Completed
Heated Catalyst...............Not Completed
Evaporative Sys...............Not Completed
2nd Air System................Not Completed
A/C Refrigerant................Not Completed
O2 Sensor........................Not Completed
O2 Sensor heater............Completed
EGR System.....................Not Completed
Plz help me out.
Trouble Codes:
Pending Codes:
Freeze Codes:
Readiness Test
Plz help me out.
I would double check the O2 sensor and make sure its mounted correctly. If the kit specifies it be mounted in a certain direction make sure its correct. I know with my Perrin intake if the sensor isnt mounted on the bottom it wont work at all. Thats all I can think of...
... Don't buy things from ebay like bomz and it's a REV limiter not a party stopper . Ok, I know that didn't help much but it needed to be said. Now, to correct the problem. Check your MAF sensor that you mounted in the intake. You're checking for any sort of build up or things like that. DO NOT Touch the sensor itself, you'll only make it worse. Chances are you may be buying a new sensor. I'm also curious as to the type of filter you are using, it might be worth your time to invest in a AEM Dryflow filter. You must also be very careful if you were messing with anything electrical, a friend had fried his sensor when an electrical current hit his intake.
had this happen to me about 3 weeks ago, You are in limp mode and your MAF is fried. Install youe OEM airbox back into your car and get towed to the Toyota dealership, its a quick easy and warranty fix. If you take it in with the intake it'll cost you 168 bucks.
BE VERY VERY VERY VERY careful if you cant get towed and have to drive your car. Your car is in limp mode for a reason and will not go above 3000 rpm's for reason as the car should not be driven if at all possible.
eneded up costing near 300 cause i didnt put the air box in when i got it towed there
dont put you stck back on and go to the dealership. you made a mistake, now you need to go fix it. Suck it up and pay the money to get it fixed. I'm not trying to be mean, but just dont try to play it off like its not you'r fault.
Music City Scions
But that is the american way nowadays right?^^^ Yeah, this could have been avoided by buying a high quality intake instead of some cheap a$$ed ebay crap. If they cost 300 dollars for a new one, heck there went your AEM cold air intake right there!
Well, tell you the truth I don not own XA....... It's my friends, so yep he got one from Ebay got him self in trouble and asked me to help out. Well I told him the same thing DO NOT SHOP FOR PARTS ON EBAY!!! but do people listen? NO!!! So I wrote this post for him hoping that may bu I have not noticed something when I looked at the car. Well I told him to go with AIM and ask for his money back for the other one (thats what he did) as for sensor I told him to go and buy one. (make mistake be willing to pay for it)
but thx for you help ppl and no none of you sound or look mean to me.
Music City Scions
Good to hear and I hope it works out for him. If he didn't already buy the AEM one there is a high quality one on ebay that is a dublicate to the Injen short ram for 69 bucks shipped. I have it and love it. It even comes with a high quality round K&N filter.
Here is the link if he is interested
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
eric_m
29
10-12-2003 08:22 AM
