Is my battery dead?
Thanks. I am sorry I was unclear. I knew how to jump start.
I was asking how to test if the battery is needed a replacement. And is it normal for the battery to die if left for a couple of weeks unattended, or I have to do something with it in that situation.
If you get it cranked, do like dd suggested, go get it load tested. It sounds like a dead cell. Normally, a good battery will stay hot for at least a month or 2.
Do you have any mods that could cause a drain?
I don't see how either of those would cause a drain.
Simple test...park the car as usual(preferably in the shade), pull the pos. terminal on the battery and look to see if there is an arc between the post & the terminal. If there is, you have a circuit drawing juice.
Then, you just have to find what that circuit is.....
same thing to my bro's xA. . .he hadnt used it for a while and it wont start. . .
when we open the door the lights wont even turn on, the beeping noise wont beep when u leave the key in the ignition, and the remote key wont unlock/lock the doors. . .the battery indicator says that its "ok" so we tried jump starting it but no prevail
so maybe its just a dead cell? any other suggestions?
Same thing with our xA, the OEM battery died, so we got a Red Top, The car went to paint and the battery died and could not be saved, So we got another battery, and after a week of not being started, the battery was toast. So I disconnected the underglows and the 12volt converter, now just waiting on our new battery to arrive. I am gonna do the arc test that oldmanatee suggested. I really hope that the electrical is shot.
Thanks for the reply. I think something happened to the car at that time because it would hit me with a joilt each time I walk out of it and touch something like house door. Then a dealer did something to the car while changing the oil and it has not hit me yet since that.
Blunderbuss
10-08-2015 04:56 PM
