TRD lowering springs and 17's
i was wondering if anyone had pictures of their xA with TRD lowering springs on [stock shocks/struts] and on 17's. the reason im asking is that i just put on 17's on my xA but the fender gap is so HUGE that it makes my 17's look like 15's. i was hoping that the TRD springs would lower them enough to at least make my ride not look like one of those wind up toy cars. thanks.
Check out the pics of my car in profile or in the RS1 thread. I've got the TRD springs and the Enkei wheels are 17s. I think it took the wheel gap enough for it to not look obnoxious, and dropped it low enough that it doesn't also look overdone. The ride is a bit more stiff on stock shocks. If you travel bumpy roads, you'll be feeling it all.
Edit: Here's a better pic
If you want to go half an inch lower (1.5" total), look at Teins, and if you want the full 2 inches, look at Tanabe df210s or Goldlines.
how long did your stock shocks last on the TRD springs? [im asking both of you guys]
thanks for responding by the way.. your photos helped out a lot, i put in an order for a set of TRD springs from Scion Parts People.
I just put my TRD springs in a month or so back. So I can't really comment. I'm thinking I'll be going to the TRD shocks maybe next spring. Mostly because I don't want to do another alignment this year again. If you got the cash, grab the springs and the shocks at the same time. May as well get them done while you've got them all out for the springs anyhows. Supposedly that will bring the drop down slightly more, and hopefully make the ride a bit smoother. (Wont know till I get around to doing it, I guess.)
The springs were my first mod since the wheel gap in stock form was really bad. I still want to go a bit lower but can't afford coilovers right now.
just for a comparison I know it says stock shocks but I have TRD shocks and springs and pics are of 2 different rims with 2 different tire sizes
First the newest one 17x7s 215/45s
Second one is 17x7s 215/35s
Notice the HUGE difference in wheel gap between the 2 diffent tire sizes
Originally Posted by SherbertXA
Do you guys think it would be that bad looking or that big of a gap with 15's?
i did some research and i spoke to my friends that are gearheads and they told me that i needed to lower my car in order to fill that ugly a$$ gap. with my situation [and setup] i decided to go with TRD lowering springs [which would give me a 1" drop]. luckily some people were kind enough to respond and post up pics of their cars with the mod already done so i would atleast see how my car would look if i did use the TRD's.
comedykills brought up a very good point with the tire size. PAY ATTENTION TO THAT. my tires are 205/40's, the same size as those on the rs 1.0.
with 15's i'd imagine that you would have to lower your car more than if you had on wheels with a larger diameter. [i may be wrong.] look up the xA spring rates in the suspension and handling section, they should help you decide on which springs to buy. one other thing i found out [from a response and from my friends] that you may want to keep in mind, the lower you go the harsher the ride will be on stock shocks. also, if you lower your car beyond a certain amount make sure that your shocks are able to handle it. and make a post to see if anyone has a lowered xA on stock wheels [or with ur specific setup]. i think i ran accross some when i was doing research.
ps. i dont know if you already know this but the gap won't be noticable if ur right next to the car looking down on ur wheels. u would have to be at least 6 feet away to see.
The overall diameter stays the same when go plus 1, 2 or 3 inches in rim size if you use the right profile ratio. Thus the gap remains the same. If you change the ratio then the overall diameter changes but you also change the gear ratio and it will throw off the speedometer. Here's a great tool for comparing rim sizes and tire ratios...
http://www.miata.net/garage/tirecalc.html
RIDE UPDATE
after sitting in my garage for about a week my TRD springs finally went in and heres how they look.
before
after
i know its not much of a "before and after" pic but the gap difference is really noticable.
i am very happy with the results thank you to everyone that replied and helped out.
before
after
Scion0814
Scion xB 2nd-Gen Wheel & Tire
02-12-2015 01:41 AM
