2004-2006.5 [NCP61]
Water Pump Replacement
Old 02-21-2011 | 01:50 AM
SkylineMan's Avatar
Default Water Pump Replacement
Ok i have a 2006 XA and im tryin to replace the water pump, but i cant find the belt tensioner to loosen the belt on the alternator and water pump. can someone tell me where the hell it is?
Old 02-21-2011 | 02:07 AM
DJ_SpaRky's Avatar
Loosen both bolts on the Alternator, that acts as the tensioner.
Old 02-21-2011 | 02:22 AM
SkylineMan's Avatar
which two bolts the ones on the bottom of the alt. or other ones...not the one in the middle right?
Old 02-21-2011 | 03:10 AM
SkylineMan's Avatar
bump...
Old 02-21-2011 | 03:31 AM
SkylineMan's Avatar
okay i got the top bolt but the bottom bolt will no move at all. any tips how to get it off. ive been tryin this whole time.
Old 02-21-2011 | 04:20 AM
SkylineMan's Avatar
bump.....
Old 02-21-2011 | 04:31 AM
tc-guy's Avatar
there is a 12mm bolt on top. then there is a 14mm bolt right underneath the alternator. hard to get to and see. loosen the both bolts only. do not need to take all the way off. i haven't done one on the xa but on the xb you will need to take the right side motor mount bolts off and let the engine hang down to get the waterpump out. hope that is not the case with the xa
Old 02-22-2011 | 12:08 AM
SkylineMan's Avatar
it is but the motor popped up. and im tryin to take the connecters out the front of the alt i got the wire harnest out but theres another one with like a gray cover and i cant get it out. idk anything about xa lol its a new car but its used but its new to me lol
Old 02-22-2011 | 01:30 AM
SkylineMan's Avatar
okay without a lift or a engine lifter what is the easiest way to get the motor back down on the frame from the mount?
Old 02-23-2011 | 04:46 AM
DJ_SpaRky's Avatar
I never had to unmount the motor, just the airbag sensor, but only because I don't have airtools and really like run-on sentences, they are the awesome.
Old 02-23-2011 | 02:12 PM
vettereddie's Avatar
Use a standard floor jack. Put a block of wood between the oil pan and transmission under the engine, jack the engine up to clear whatever it's hung up on, move it into position, then slowly lower it down over the mount point.
DaBlackBox
134
04-10-2022 03:04 PM
archael666
03-20-2019 12:52 AM
blh72
Scion xD Wheel & Tire
02-02-2015 01:36 AM
torranosaurus
01-28-2015 05:53 AM
smilygo
12-30-2003 08:45 PM
