'06 xA Air Conditioner..
Old 08-30-2007 | 11:20 PM
cobb's Avatar
I was at a cvs last week looking for the disposable video camera. I found in the auto isle they had 2 mini roll up blinds for your winows. They are 3/4 the width of the rear passenger windows. I installed them on my rear windows and its the best 10 bucks I spent. The car gets cooler faster inside and stays cooler with a lower fan setting than in the past. I only use setting 4 to start cooling the car, then setting 3 or 2 to keep the car cool. Amazing.... If it werent for my need for speed I would get my windows dark as legally possible. Cops told me in the past they look for 2 reasons before they pull you. They will let you go if you go over the limit, but reckless driving, no turn signals and or tinted windows, you got a stop.
Old 08-31-2007 | 03:34 AM
SCIONOSIS's Avatar
I don't know if this was mentioned already, but has anyone tried washing out the condenser. Accumulation of dirt, bugs, pebbles, and etc. possibly could alter heat exchange with ram air flow temps at the condenser. I'd start with this remedy first.
Old 08-31-2007 | 03:45 AM
tripntrance's Avatar
i agree on r134 not as efficient as r12.
Old 08-31-2007 | 11:36 PM
cobb's Avatar
I hadnt cleaned either my condensor or evaporate, however its a new car. I installed a filter at around 3 thousand miles.
I am happy now, those shades made a world of difference.
Old 06-20-2008 | 07:33 AM
ANightDriver's Avatar
Originally Posted by TheRealBen
When I got my 06 I realized my ac didn't work at all, just take it to your dealer and have them check it out.
If the tips on here don't work, perhaps they know of something that will work in your area.
Thanks. My ac has stopped working. The dealer wants to replace the compressor. Hope they put this on the waranty.
Old 06-20-2008 | 04:01 PM
DVSAZN's Avatar
In TX (up to 60 days of triple digits) myself on a 06 xA and my A/C runs great as long as it's moving... But that's with any A/C system, the more air you're moving through the coils the colder your air is going to be...
Of course if you're in stop/go traffic your A/C isn't going to be as cold...
Tint helps tremendously...
Recharge your freon, and opt for the freon additives most dealerships sell... Help to lubricate your A/C system and drops your A/C temp by like 20% I think... It helps...
Old 06-21-2008 | 02:57 AM
cobb's Avatar
Theres a thread in the xb forum about installing an extra fan on the condensor. Tint has made a world of difference for me.
Old 06-22-2008 | 08:54 AM
INFINI's Avatar
Originally Posted by MaxiVisVires
Would fabbing a second fan be the answer to the problem? I don't really think it's the fan speed that's the problem, it's the air isn't cold until I crank it to 3.
For me it depends on how hot it is outside. Direct sunlight. I find for the most part daily city driving makes for longer cooling times. Highway is great. At level 3 and up for me is not as cold as level 2. Seems there are some discrepancies here in the A/C in the xA
Tint helps allot cause the int. stays cooler in gen. Just the truth. However it's like putting in a light pulley. The results are not like putting in a turbo.
fabbing a second fan? lol where is that DIY?
Old 06-22-2008 | 10:30 PM
jct's Avatar
jct
thats my thread
https://www.scionlife.com/forums/viewtopic.php?t=225622
i've got my windows tinted and it helps alot
you can get a fan for less then 75 dollars alone you still need to hook it up with switch and maybe a relay
Old 06-23-2008 | 12:55 AM
onestinkydog's Avatar
I agree. my altima i can run the ac and it cools under a minute. I solve the AC problem by moving to a cooler city...Buffalo NY
Old 06-23-2008 | 01:30 AM
INFINI's Avatar
Errrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr that not an A/C solution homes...
Old 06-23-2008 | 01:56 AM
cobb's Avatar
I have the old relay kit from my old fog lights, I can use that to power the fan. Got to get the fan now. I looked at a 10 inch one at pepboys, but it needed to be bolted. Another brand I saw a few years ago used zip ties to tie or sandwich it to the radiator.
Old 07-06-2008 | 04:22 AM
Belle's Avatar
Default Re: '06 Xa Air conditioner
Were you able to get this fixed? I feel your pain -- I live in Phoenix AZ also, and the A/C works pretty well in my Xa. Not as well when idling (so a remote may not help that much), but it cools the car down fairly quickly and is icy cold, even when it's 115 degrees here. The ventilation ailment that mine has is that it can't pull in cool outside air when the lever is set to "Fresh Air" -- the incoming air is always hot, even if it's 50 degrees at night (i.e. no sunshine effect) and I'm in Flagstaff. I hope you got yours fixed -- if you ever found a responsive dealer in the Valley, I'd love to hear about it. Good luck.
Old 08-13-2021 | 08:47 PM
Kerry's Avatar
Does anyone know of a more effective brand of A/C (or upgrade) for a 2006 xB Scion? Mine is OEM.
The last time I topped off the refrigerant Toyota said it might cost $2000.00+ next time because they'd have to remove the dashboard. Yikes! They added a colorant that will show future leaks. The top-off is still cooling after a year.
Also, should I have Toyota do the major repair the next time or would an A/C shop do as well, perhaps cheaper? My thinking has been that Toyota's mechanics are familiar with '06 Scions but other AC pros might only get to work on one once in a while and might forget a step.
Thanks, Kerry
'06 Scion xB
Old 08-20-2021 | 05:43 AM
adorable's Avatar
Huh?
Unless they're in the dash replacing the compressor etc, a flush and recharge shouldn't be more than a few hundred dollars.
Or, you're screwed with a underpowered compressor from the factory
https://www.scionlife.com/forums/sci...ac-tsb-103837/
(Scion xA has a TSB on the weak A/C) and Toyota didn't tell you about it (meaning they screwed you out of a free replacement).
Then they'll quote $3000+ to replace the compressor with the right one. ​​​​​​In the meantime, you're stuck sweating in the Summers.
___
Zombiecustoms
04-19-2015 11:13 PM
Envoy02slt
Scion tC 1G ICE & Interior
14
07-25-2006 04:32 PM
iowagary
05-19-2005 05:09 AM
FASTER345
02-05-2005 04:16 AM
Xonic
11-05-2004 10:51 PM
Quick Reply: '06 xA Air Conditioner..
