120k on my car, what belts need to be replaced?
hey guys, reached 120k on my xb and i've never had any of the belts replaced. never had any problems but want to do preventative maint. which belts do i need to replace?
i got mine done for 50bux including the belts,tax,and work, but its much cheaper to do your self if your up to it, just be careful for the camshaft position actuator thing! the first time i had to replace mine i DIY'd and busted it! turned a $15 replacement to a $120 job.
I'm not sure about some of the internals of the engine, just wondering if it would be easier to upgrade since the belts are being removed already.
but if this is your DD id say leave them be if there not broken/bent/worn. SOME aftermarket pulleys can cause unfavorable side effects, like not enough power to the alternator or overly stiff steering. the only real up to having lightweight or underdrive pulleys is reducing drag and moment inertia, the HP gain is almost negligible in our cars, maybe 1-3HP max.
Yes, The '06 xB has 2 belts as stated above. All internal is chain. Just got back from dealer here in AZ and they wanted $175.00 to do belts (2). Got decent Dayco belts at Pep Boys for $35.00 and will install myself as there seems to be a bit of room in there. Any "sticky's" or step-by-step on this, or is that even needed?
As always....Thanks to all!!!
Socks
Socks
Socks
Socks
