13b motor swap
13b motor swap
i hear alot of talk about swaping 2zz motors and other motors in xa's and xb's
and i wondered if a 13b would fit or the new rx8 motor i no that one is smaller.
i wanted to no if u all thought it woud be possible it would be killer if it is.
pfffft
that aint nothin
forget those engines and go all out with one of these monster engines!!!
636 cid hemi engine from indy cylinder head all for the price of $31,750.00 rated at 1120 HP@7400 RPM, 930 Torque@5800 RPM it'll smoke any honduhhhhh that comes up to the line
heres the specs for it
http://indyheads.com/id2.html
4.500" Bore 5.00" Stroke ,Race Gas, Dyno Tested & Tuned,Indy Maxx Alum Block Raised Cam ,426-1RA6 CNC 325 Heads ,Indy Tunnel Ram-Full Port & Polish ,Titanium Valves (2.400"X1.94") ,Callies 4340 Crank (5.000" X 2.200") ,(2.40X1.94,166cc) ,Indy Wide Pan Oiling System BG Fuel Lines & Regulator ,GRP Aluminum Rods (6.950"X2.200") ,Comp Roller Cam & Lifters(HR4) ,2 -1195 King Demon TR Carbs ,ATI Balancer ,Wiseco16to1 Pistons Tool Steel Pins ,Indy Cast Aluminum Valve Covers ,MSD Distributor and Plug Wires
* Upgrade to Crank Trigger Compete and Mounted
* Upgrade to Indy Dry Sump Oiling System Stage 1 #363 (Includes: Pump, Pan, Pan Fittings, Adaptor Plate, and Scavenge Lines from Pan to Pump)
if i had a 100 grand i would so do this!!!
that aint nothin
ok, the engine swap idea has been covered numerous times. Please do a search on it.
Any engine swap is possible, providing you have the funds to back it up.
https://www.scionlife.com/forums/vie...ht=engine+swap
LOCKED!!!!
LOCKED!!!!
10spokess
14
11-07-2016 02:43 AM
