2.0 stroker kit
#101
Originally Posted by KangaRod
LoL
Not that I don't believe you, but you can't claim to have a 4AGTE swapped into your xB, and then claim you don't want to show anyone because its custom. Of course its custom. I would think that after investing so much time and money you'd want to show it off instead of keeping it so secret.
Or are you one of those guys that lives their life a quartermile at a time, and pops their hood for nobody?
There are so many flippin' ricers on this site, I don't know who to believe anymore.
Cya
#102
pics and dyno sheets speak volumes.... there are role models who post pics and dyno sheets follow their lead and post evidence or stop blowing smoke.........
#103
A 2.0 stroke is one of those things to be proven around here. Thats a huge stroke. Post, and get it over with.
Good luck if you are doing it,
Cya
#104
Stroker update
Whats up guys just give you a little update on my project.
Iam going to have a custom stroker crank made for my x/b. My engine guy has a company that will do it for cost. for a little r&d, I don't know how big of a stroke you can go with that 1.5 motor. I hope 2.0 or 1.8 it depends on the rod ratio and clearance in the block for the bigger crank.
Iam having my heads ported just on the roof and the blitz s/c intake as well to help the flow without killing my bottom end torque. Of course I will have the block sleeved plus forged pistons and a custom set of forged steel rods. also bump the nitrous from 50 to 150.
Also my engine guy thought it would be a good idea to mod my aem cold air intake to run a cone style filter that flows air down the center of the filter, and make a inlet on the front of my air dam with a wire grill to get fresh air like a ram air system.
Last but not least dyno tuned by a pro import racer to get every hp out of my engine combo. When this is all said and done I will post some pics of the motor.
Freddy
Freddy
#106
i'm willing to bet the valve to piston inferrence is pretty close. not 2zz close but at such high compression it'll be damn close. so for you to run a stroker kit you'll need lower comp pistons which will pretty much make f/i the only thing for you..
#107
2.0 rotating assembly
KangaRod
Iam not going to say which company is making it. You guys will know when it hits the market for sale.
hotbox05 As for the valve kissing the piston the shorter rod will give me the clearance I need, I haven't talked to the crank company yet but I don't see any reason to lower the comp on the pistons. I could run the ones with vavle relief cut into the piston for more clearance.
I only thing Iam worried about is the rod ratio, I need a much shorter rod if I want a 2.0 or 1.8 stroke. In the end it will be up to the crank company to make this work, how they do it I don't really care just give me my 2.0 stroke. I will settle for 1.8 but that's is small as I will go.
Freddy
Freddy
#108
Re: 2.0 rotating assembly
Originally Posted by Freddy
KangaRod
Freddy
Freddy
You'll settle for a 1.8 vs. 2.0? YOu do realize how big of a stroke .5l is on a small motor? With all the money spent, you might as well buy a 1zz and stroke it to a 2.0 vs. 1.5 to 2.0. You need to start caring if you want your motor to run with all this you are doing.
If it were easy, there would be a good handful of us with stroked 1nz's, including myself.
Cya
#109
KangaRod
#110
KangaRod
Freddy, show us proof or otherwise forget "keeping everybody updated" because no one is going to believe, maybe some newbies but the way you talk you sound like a newbie. No offense, but you do.
If you really want to stroke or swap motors, ask us for help. We are here to help you if you get rid of the bs.
Cya
#111
Whatever
Kangarod;
The only reason I don't say who it is because it's my engine guys friend. I don't want any dummies calling up and wasting his time and annoying him on the phone.
Turns out that going to the shorter rod kills the gain in the stroke. I could try to stay with the stock size rods but that means the pin will be far up in the piston then you have a oil control problem.
Forget that, Iam going with the stock crank, aebs sleeved block, aebs ross forged pistons, aebs forged rods and bump my nitrous from 50 to 150. plus port the head and blitz s/c intake and make a ram air for my ame cold air intake, then dyno tune the set up.
PS: You do not have to lower the comp on the pistons to run nos, cams will be stock, my engine guy said the nitrous will be fine with stock ecu and the piggyback blitz ecu. I have a 255lph fuel pump, ford fuel injectors 320cc and aeromotive fpr and perrin fuel rail and a return style line line.
Freddy
Freddy
#112
Re: Whatever
Kangarod;
Freddy
Freddy
Cya
#113
Killerromances
The intake is cut 2-3 inches shorter so now the filter points foward instead of down, next you install a cone style air filter that flows through the center and next cut out a inlet in your front air dam and make up a wire grill panel to fit into the opening. As far as what you believe thats on you but I will post photos and time slips when Iam done with this project. until then you will just have to wait. As for your newbie comment I have been drag racing nhra for the last 20 years in heavy street, mean street and top street.
Freddy
Freddy
#114
Killerromances
Freddy
Freddy
Cya
#115
dude. that motor wilkl die. 150 shot will make this motor die.
just get a stout motor and swap it into this car....
think zz or 4ag. hell go buck wild and try 3sgte.
#116
Hotbox05;
With my ABES sleeved block and ABEs ross forged pistons and AEBS forged rods and arp bolts Iam not worried at all if by chance I blow this one up I will try to shoehorn in a s/c tc motor.
Freddy
Freddy
#117
Hotbox05;
Freddy
Freddy
And you will blow your motor, don't worry about that. You said so yourself the new rod is the same size as stock. That will snap in a heartbeat.
Cya
#118
I was going to say something about the 'shorter' rods and it basically cancelling out a longer crank, but it looks like you corrected yourself on that one. As far as putting in a 2.4 tC motor....Good luck with it. I would rather try the 1ZZ as the intake and exhaust sides of the motor are on the same sides as the 1NZ. Whatever you do, good luck and I'll be shocked WHEN AND IF you get it done.
The funny thing on this WHOLE post is the original title was YOU asking about it and wanting to know how to do it, but as this thread gets longer, you continue to answer YOUR OWN questions...
If you already know this stuff, why did you start this topic? You and your "engine guy"seem to know all the answers....so why keep re-hashing? Just get it done and SHOW US! I mean, if you are just 'brainstorming', FINE, but try not to come on here wanting answers, then get shot down by others and then type in answers to the questions YOU were asking to try to prove evryone wrong! Everything you have stated gets shot down, but you always have an answer to come back with after they keep telling you it won't work. Seems weird, thats all! Good luck with it!
#119
No more update posts until project is finished
Last post until my x/b is finished and out of the shop and running. Will have photos and timeslips so thats that.
As far as starting this post I was looking for a stroker kit. If I found out some info I would post to update and not to answer my own questions. But sometimes I did. As for getting shot down I just would post what step Iam at with my project.
If I had a dollar for Every time someone says it can't be done I would be rich, hey sometimes it won't work and you have to find out the hard way. but nobody would ever get any wild projects done if you stopped every time you heard that.
Freddy
Freddy
#120
Re: No more update posts until project is finished
Freddy
Freddy
