2005 xB A/C stopped blowing cold air and now Radiator fan won't turn on
Old 07-05-2020 | 12:40 AM
Mcannup's Avatar
Default 2005 xB A/C stopped blowing cold air and now Radiator fan won't turn on
So A/C stopped blowing cold air. Turns out A/C compressor was bad. I replaced it. Tried to fill with Freon and it only took about 1/4 of can. Did more research and said to replace expansion (?) Valve. So I did and replaced both Low pressure lines. Vac the system, holds pressure no leaks.
Added almost a full can, still no cold air and pressure gauge was almost in red. When checking the air with car running I noticed the radiator fan never kicked on. Checked fuses all good. Replaced thermostat and flushed the system. Fan still not working and still no cold air.
Can someone ease give me any useful information? I've spent the 4th of July busting my knuckles and aggravated.
_____
Last edited by MR_LUV; 07-05-2020 at 06:13 AM. Reason: Moved to Correct Forum by Administrator
Old 07-05-2020 | 04:12 AM
haydcarpenter's Avatar
Does only 1 fan work or are both fans not working? I’m having a similar problem but 1 fan is working.
Old 07-05-2020 | 04:22 AM
Mcannup's Avatar
The A/C fan works and I'm finally getting cold air. Apparently I just didn't put enough Freon into the system.
The coolant fan is another issue. All the relays are good. I checked wiring harness to coolant fan with multi-meter and didn't get a reading.
I'm thinking it's the temp sensor. It's only $24 so I'm gonna replace that to see if that fixes the issue. I'll keep ya posted
____
Old 07-05-2020 | 11:07 PM
Stames's Avatar
Does the xB have a condenser AND radiator fan? The xA only has a single fan.
Is there no fan turning on when the A/C is on and working?
____
jotalbert
06-12-2015 08:20 PM
jizzypickle
01-16-2015 11:03 AM
BlueRocket
09-15-2014 06:50 AM
pwee08
08-29-2009 02:34 AM
xdejablu3x
Scion tC 1G ICE & Interior
01-13-2007 05:02 AM
Quick Reply: 2005 xB A/C stopped blowing cold air and now Radiator fan won't turn on
