30 ft/lb Injectors Where?
I was looking for these fuel injectors all over the place and couldn't find any 30 ft/lb (except for a firebird and a camaro). I then went on ebay to see if there was anything there for a Scion, but nothing. Just wondering if they sold 30 lb/ft injectors or anything close to that for an xA, and if so, where. Also, I'm not sure if you can use injectors for another car. Someone on another forum was talking about them and said how they could get the xA's hp up a bit, which is why I was interested in it. Anything anybody knows would help alot... because I don't know anything to be honest. Thanks Alot.
Originally Posted by Back In Black xA
I did some research on the Toyota database and NZ and ZZ engines all have the same fuel injectors, about 200cc injectors, even the Celica GTS. Camry 2AZs have about 350cc injectors though.
And yes, they are definately a lot more fuel on the stock program. When I installed them, it loaded up really bad off boost .
That was before I tuned it.
Oh, and 310cc is about 30lbs/hr. Celica GT-S injectors can be had pretty cheap if you look in the right places. I got mine for $110 shipped from a wrecker I found on www.car-part.com and it came with a fuel rail (which I obviously didn't need lol).
Injectors 101...
The 1NZ-FE uses 200cc Injectors with 8 holes for spray, this is better for economy and emmissions since the fuel atomizes before goes ka-boom
The 1998 Non-VVTi 1ZZ-FE uses 200cc injectors 4 spray holes, these allow more fuel to get into the chamber, a little bit better for performance since the fuel is hitting the top of the piston.
1999-2000 Non-VVTi 1ZZ's used the same 200cc injectors that the 1NZ uses.
2001 and up VVTi 1ZZ's used 250cc injectors
The 2ZZ uses I believe 300cc injectors
The largest injectors that bolt onto our frame rails are from Tacoma 4Cyl's, those I believe are 320cc, but dont quote me on that.
Originally Posted by PSyCHo-RaGe
Injectors 101...
Does anyone know the mpg loss this would have on the xA, or other things that would happen if installed. Is it true that the car could get 150 hp from that. If so, what's the point of getting a turbo charger if it only costs 100-200 bucks?
Team No Limitz
Dont bother...get either the yellow or gray 2zz injectors. I bought mine for like a $100 used. I guess it also depends on what your trying to do w/ them...you running a supercharger or turbo??
SloTC1
08-16-2018 02:45 PM
retrodrive
35
07-14-2006 07:52 AM
