87 89 or 91
87 89 or 91
I looked through my xb manual and I'm not really sure what type of gas would be best for my application. I want to concidering the fact my mods may have something to do with it (aem cai, dc header, rsr exhaust, jdm style grounding kit) I use 91 premium... would I be better of useing anything less (87 89)??
Run 87. Thats what the book says. All you are doing is wasting your money on any thing above 91. You only need premium when you are boosted or sprayed. So you have those simple parts, it did not increase the CR or anything. So no need for higher octane. About the only way you might need it, is if the engine knocks using 87.
Originally Posted by TXboxdriver
what is 91
we have 93 here in Tx
Originally Posted by phatcyclist
I had to put 86 in my car a few times, on a road trip. The car will run fine, even at real high altitudes (around 10,000 feet) on that fuel.
what is 91
this engine is designed to run on regular unleaded fuel
anything more than this is a waste on a stock motor (not boosted!)
All the bolt-ons won't even stress the need for more expensive fuel (again**except boosted applications**)
the higher octane numbers do nothing for MPG....the numbers represent the amount of anti-knock additives that are in it...you dont gain any more power or anything... but if your bootsed or spraying you run less chance of detonation the higher the octane
yep, the higher octane gas is harder to ignite, and is for use in situations of high heat and pressure.
most cars have a sticker on the inside of the fuel door that tell you what grade to use. best bet is to stick with that unless your engine has been heavily modified (boost, internals that change compression and/or displacement etc.) even then, most turbo or SC kits will tell you what grade of fuel to use.
