Another Dummy Light Question
Hello brother & Sisters,
I have read on here about how to reset the "Oil Change" check engine light. Also saw about the ECU fuse trick for reseting the system. The only thing that I have done is replaced the ABS line in the rear of my box due too a rock getting caught in my RsR Lowering spring and wearing a hole through that line itself. I got a replacement and installed it. Tried all the above mentioned tricks and still can not get that F**k**G ABS,VCS,Traction Control & E-Brake lights 2 shut off!! Anyone have any ideas The only other thing I have changed is I put on an ingen short ram and I saw on here the people were having a dirt issue? I will try & clean that out tonight, but besides that all fuses are good and that is all I got?
Thanks in advance for all your help!!
Which light is actually on? The Maint Req would have nothing to do with the ABS line. The Check Engine might not either, since I think there is a separate light for ABS itself.
You may have to just stop by the dealer and have them reset it.
Ferretgrrl
10-15-2018 02:50 AM
