Big problems Help!
Old 12-24-2006 | 04:59 PM
biohazardous_customz's Avatar
Default Big problems Help!
ok here is the situation.....driving last night and right after i shifted into second and gave it gas the car faded out and died.....felt identicle to a car running out of gas....but there is 3/4 of a tank in it, tried to turn it over and i am getting spark no problem but not getting any fuel it seemed.....checked all the fuses and the number 5 fuse under the hood(efi 15) was blown...replaced the fuse and as soon as i truned the key to acc it popped. well after about an hour and a half of eliviating what it could be we rulked out the whatever was making the fuse pop was not the fuel pump or injectors shorting.....checked the efi relay and it seemed to be ok.....anyone have any ideas on what could be causing this i need the car running by christmas day and of course dealers are out of the question.....please help
justin
Old 12-24-2006 | 05:06 PM
cherryBox's Avatar
can i hear a run-down of all the electrical mods that you have, and the source of their power?
Old 12-24-2006 | 05:09 PM
Mightygnu's Avatar
definitly needed ^^ ... never heard of this happening..
Old 12-24-2006 | 05:19 PM
i have a full system and lighting mods but eveything is fused and sourced from the battery to my own switches nothing tapped into the fuse block of the car at all
also the wierd thing is that nothing changed at all on the car just gave it gas and it putted out.....so i am not really sure what could have happened to cause the fuse blow i was thinking possibly a bad relay.....or i know they are linked to the efi but not really directly my O2 sensors i have thrown an O2 code a couple times in the past 2 months
Old 12-24-2006 | 05:33 PM
Metro273's Avatar
Unfortunately it sounds quite possibly like a "shorted" fuel pump. I work at a dealership and we've had this happen on a few occasions.
Of course, this is what I'm thinking it is and I hope, for your case, it isn't...
BTW, you stated above when you replace the fuse and when you put the key into "acc", it blows. This is a dead give away that it's the fuel pump...
Old 12-24-2006 | 05:36 PM
exactly what i was thinkin but i diconnected the harnesses to the fuel pump and replaced the fuse and it still popped......so i pretty much figured that would prove the short is coming from elsewhere
Old 12-24-2006 | 05:40 PM
Metro273's Avatar
You might want to perform an "ohm" reading on the harness from the fuel pump harness connector to the fuel pump fuse cause it also sounds to me you might have a "shorted" wire somewhere. Hopefully you have a multimeter.
Old 12-24-2006 | 08:45 PM
yeah i have one.....I just need to look up and see what voltages I should be reading so i have something to compare it to.....but all this will have to wait til tomorrow night to do because i dont d\feel like dealing with it ....lol
Old 12-26-2006 | 01:35 PM
bump.....trying to get some ideas here
Old 12-28-2006 | 02:30 PM
well after 2 days of digging and check harnesses and reading electrical scematics i think i may have figured it out......seems the ECM screwed up which would actually be good considering that is aboutn the only part of my car still warrantied.....but the only way to find out for sure would be to have the dealer look at it and if its noty then i am gonna get charged out the ___ soooo i came up with a solution take the ecu out of a good box drop it in and see if she runs if so then vioula we know the problem if not then gotta start digging again.
skruff
Scion tC 1G Wheel & Tire
03-16-2015 06:16 PM
missing_image
02-07-2015 07:18 PM
cid_mcdp
01-05-2015 02:45 PM
scioninla
14
10-18-2003 03:46 AM
Quick Reply: Big problems Help!
