A/C Compressor/fan cycling off and on..
Old 08-22-2010 | 04:25 AM
HiPakeMan's Avatar
Default A/C Compressor/fan cycling off and on..
I have a 2005 xB and when my A/C is running, I notice that the fan/compressor keeps cycling off and on every 20-30 seconds or so.
Is this normal?
___
Old 08-22-2010 | 05:24 PM
emptystreets130's Avatar
it's a little out there. it should cycle somewhere in range of 10-20 seconds but it largely depends on the outside temp. I believe your system is fine. You can double check
with a gauge and see if the low side pressure reading is around 29-34psi. anything higher (>40psi) is too much and results in the A/C system blowing warm air instead.
___
Old 08-22-2010 | 07:18 PM
HiPakeMan's Avatar
Originally Posted by emptystreets130
it's a little out there. it should cycle somewhere in range of 10-20 seconds but it largely depends on the outside temp. I beleive your system is fine. You can double check with a gauge and see if the low side pressure reading is around 29-34psi. anything higher (>40psi) is too much and results in the A/C system blowing warm air instead.
So it should cycle quite frequently.
The A/C blows nice and cold but I'll check the low side and see what it reads.
___
Old 08-22-2010 | 07:23 PM
frankiietc's Avatar
yes it is normal. Check your anti-freeze level to see if thats the problem also.
Mcannup
07-05-2020 10:07 PM
jhip626
07-17-2017 12:00 AM
elwaylite
08-09-2015 09:21 PM
jizzypickle
01-16-2015 10:03 AM
blazeplacid
06-14-2007 11:30 PM
Quick Reply: A/C Compressor/fan cycling off and on..
