CEL on, codes pulled, need help
Old 04-07-2009 | 01:56 PM
jizzypickle's Avatar
Default CEL on, codes pulled, need help
So my wifes XB (2006, mt, less than 40k miles) has had the CEL come on over the past week. I checked the codes, and reset the ECU, but about every 3 days, it comes back on. I had the codes pulled at an AutoZone, and its kinda vague. I was hoping you guys could help me out. The code sheet that was printed out reads:
BBEvaporative emission control system pressure leak
BBdetected - small leak
Probable Cause
bb1 - Faulty Fuel Cap
bb2 - Evap line leakage
bb3 - Pump Module Failure
bb4 - Canister Faulty
The car runs fine, no changes in idle, performance, or fuel economy.
After resetting, the CEL will come back on after 3 days.
I checked the gas cap to make sure it was on properly.
So here's my questions:
For those of you who have thrown this code before, what was the end cause of it?
Out of the probable causes listed, I can pretty much rule out the gas cap or the pump, because I checked the cap, and the car is obviously getting enough fuel to run properly. So where is the "canister" and how do I check it?
Also, where are the evap lines?
Thanks,
Matt
Old 04-07-2009 | 02:29 PM
draxcaliber's Avatar
basically it is an evaporative emissions problem, and you need to use a smoke test to see where the leak is coming out of and replace whatever is leaking.
Old 04-07-2009 | 02:39 PM
beandip007's Avatar
I have the same thing with my TC. I have heard of faulty charcoal canisters, but I have not done anything to fix it yet. I am looking to find the problem also.
Old 04-07-2009 | 02:41 PM
care to elaborate? what is a smoke test, and how do you go about doing it?
Old 04-07-2009 | 02:47 PM
beandip007's Avatar
they apply smoke into the fuel system to see where the smoke comes out at. Then when the smoke is found they replace what is bad.
Old 04-07-2009 | 02:49 PM
it is what it is, you put smoke in the evaporative emissions system and pressurize it to see where the smoke comes out, thus revealing where the leak is.
http://www.denlorstools.com/home/dt1...ester_use.html
Old 04-07-2009 | 03:06 PM
thanks for that.... but where is the canister located? and can you give me a general location of where the evap lines would be?
Old 04-07-2009 | 05:25 PM
that i couldn't tell you, don't own an xb, but search the forum, the tech section or whatever, maybe they have some articles or DIY's for it or something.
Old 04-07-2009 | 07:00 PM
cherry-8's Avatar
I fixed my wife's Camry a while back that was showing the same codes. Replacing the fuel cap did nothing, and I could find nothing wrong with the hoses for the evap system. So I pulled and tested the vacuum switching valve (VSV) from the intake, it was ok. There's another VSV on the charcoal canister and that one was bad. The dealer wanted a few hundred bucks to replace the whole canister assembly. The valve was $57 or so.
Section 12 of the xB shop manual covers the evap system thoroughly--part location, diagnostics, and testing procedures (you might need a volt/ohm meter and a 12 volt power source). The link to the pdf's of the manual are easy to find on the board. Good luck with it,
MD
Old 04-07-2009 | 07:16 PM
Reactor's Avatar
First of all see it it's still covered by emissions warranty. It may also be a subject to a recall or may be there is a TSB regarding this problem. It'snotvery likely that you have a leak in the Evap system, but there were cases when water collected in the canister,or may be a stuck valve. Search on this forum- very recently there was talk about this issue in a different thread somewhere.
whooty
04-19-2023 06:34 PM
12xb
11-07-2015 04:44 PM
xb4lf
04-04-2015 08:15 PM
D_Roke
03-31-2015 06:37 PM
AdmirN
01-05-2015 11:19 PM
