Clutch Replacement help.
Old 06-24-2009 | 01:37 AM
rockndabox's Avatar
Default Clutch Replacement help.
I am at 94k miles on my box and its about time to change my clutch. I was wondering if getting a stage 1 racing clutch would be worth it instead of getting a normal OEM replacement clutch. My box is naturally aspirated w/ borla exhaust and K&N cold air intake so I am unsure if the racing one would work well on it.
Can I get some suggestions for a clutch? Links would be appreciated.
Thanks
Old 06-24-2009 | 02:59 AM
sparcshinobi's Avatar
Great question! I can't wait to replace my clutch, too! Been wondering what others are rockin. Fitment issues? Longevity? Power difference? Just wondering.
How bout a fidanza flywheel?
Old 06-24-2009 | 03:06 AM
draxcaliber's Avatar
a clutch should last the life of the car unless you abuse it with aggressive driving. before spending money a new clutch job, is your OEM clutch slipping or having trouble fully engaging/disengaging? if it isn't, than it is fine and a new clutch isn't necessary.
as far as a new clutch goes, as far as "racing" clutches go, you're probably thinking about an unsprung clutch, do NOT get one of those, they will make the car very hard to drive on a daily basis.
but i'm sure there are a huge number of aftermarket replacement clutches that'll do just fine. just get a stage 1 clutch, or a stage 2 if you want some more clamping power.
http://www.dezod.com/cat_clutches3.cfm
theres a good selection of clutches for you to look over.
oh, and you can add a lightweight flywheel, but it will make the car harder to pull away from a stop until you get used to it.
Old 06-25-2009 | 04:23 PM
rockndabox's Avatar
Thanks. I think I'm going to go with the OEM clutch since I am 16 and the other clutch costs way too much for my budget. Perhaps I will get a lightweight flywheel in the future.
Old 06-25-2009 | 04:52 PM
Giupo's Avatar
I council the Fidanza clutch or if you engine is Oem the oem clutch
p.ss I have a oem clutch with only 8000 miles if you interests
tato63
Scion tC 2G Wheel & Tire
9
09-30-2015 09:55 PM
yhwhdesign
10
02-06-2015 05:00 AM
blh72
Scion xD Wheel & Tire
02-02-2015 12:36 AM
torranosaurus
01-28-2015 04:53 AM
baker08tc
12-30-2014 12:02 AM
Quick Reply: Clutch Replacement help.
