Coil Pack Female Plug?
Anybody know where I can get a coil pack plug without having to buy a whole new wiring harness?
Not the coil pack but the female plug that connects to the coil pack?
The clip on it broke and I think it gets loose with vibration.
_____
_____
How would you replace it? The connector pins aren't removeable so you'd have to cut the wiring and re-splice. If you're worried about vibration and want a permanent fix, you could epoxy the connector on. Only downside is it would probably get damaged if you ever needed to replace the coil pack.
I doubt the dealer would carry the connector only, maybe you could hunt around at the junkyards to find one. Does the Echo use the same connector?
The wires are removable from the connector, thats why its possible it may be sold seperately. But actually a junk yard is a good suggestion. Echo, Yaris, xA, xB, & Prius all use the same coil packs, hence the plug will be the same.
well i found out a price for a new wiring harness...an oustanding $905.90..to bad im not buying it... i dont even know where a junk yard is in my area...lol but that is my plan...to cut the connector off the old one and solder/ heat wrap it back together..or maybe i should just take the whole wiring harness. does anybody know if there any after market coil packs and wires that would be niceto have
Wow, I bought a whole motor and transmission for $500. It came with coil packs, starter, alternator, even all the sensors still installed. Didn't get the wiring harness though or I would have offered that up. Do you need new ones?
The toyota part number for the connector you need is:
90980-11885 msrp - $6.03
That doesnt come with the terminals, if you need those, the part number is:
82998-12340 - MSRP - $5.46 Each
and those come with 160mm of wire attached to them so you can splice back into your harness. That is also each.
Of course toyota sells them. The problem is that most parts guys now are so damn lazy they dont want to take the five minutes to help out a customer and get the wiring book from service, look up the connector and handle it. Luckily, I have my own books...
maybe i needa get my hand on one of those books...anyways so i ordered that part should be getting it tomorrow or by monday..i hope this fixes my car..my CEL keeps trippin and i already have a new short block new intake valves and exhaust valves for cylinder one a brand new vvti and new coil packs new spark plugs piston and rod all because of water through the inake..ive been having a cylinder 1 misfire before i got the car back from the dealership..and after i got it back it was gone for bout a week then the CEL turned on again..i checked it and its still a cylinder 1 misfire( code P0301) does anybody know whats going on besides my wiring harness plugs clip is broken?
