DeLabel battery & some SPECS DIE HARD OPTIMA
I just replaced my Panasonic oem battery with a DIE HARD GOLD.
Do you clean off all the decals that come with it?
So it just looks solid black.
What group does everyone use?
Interesting.
I just looked it up. Batteries Plus
I am not aware of a place like that on east coast.
check out Toyota batteries info-
This xB one is a group 25.
https://auth.toyotaownersonline.com/...start_batt.pdf
What are the specs on a optima for 1st gen xB?
Optima Battery Model: 25
Color red
Terminal top post (standard)
Volts 12
AH 44
AMPS @ 32F 910
Cold Cranking Amps CCA @ 0F 720
Reserve Capacity 90
Length 9 - 5/16"
Width 6-13/16"
Height 7-5/8"
Weight 31.7
Color red
Volts 12
AH 44
AMPS @ 32F 910
Reserve Capacity 90
Length 9 - 5/16"
Width 6-13/16"
Height 7-5/8"
Weight 31.7
DIE HARD GOLD
Overall Type: Starting
Battery Group Size: 25
Power Configuration:
Cell Type: Lead-Acid
Number of Cells: 6
Voltage: 12.0
Power Ratings:
Cold Cranking Amps (CCA at 0 deg.F): 640
Reserve Capacity (RC): 100 min.
Dimensions:
Height: 8-7/8 in.
Width: 6-7/8 in.
Length: 9-11/16 in.
Item Weight: 39.0 lbs.
Number of Cells: 6
Voltage: 12.0
Power Ratings:
Dimensions:
Height: 8-7/8 in.
Width: 6-7/8 in.
Length: 9-11/16 in.
pinkie1205
03-30-2015 03:31 AM
CPL_Radar
03-05-2015 05:42 AM
