Different Gears
Old 04-24-2005 | 04:46 PM
cadaver's Avatar
so overall, going to smaller numbers(i.e. 175, 165, 155...) will give increased sidewall height? instead of going to higher numbers(195, 205,215...) which only give tread width? i hope i understand correctly. i understood it all wrong.
Old 04-24-2005 | 05:10 PM
ootsae's Avatar
the larger the number the wider the tire, which also efects the the (aspect ratio). aspect ratio is the percentage of tire width v.s. tire side wall height, so a wider tire is also taller.
185/60/15 is shorter than 185/70/15, same width, same rim size, but the middle number is the aspect ratio. 185/60/15 is just slightly shorter than 195/60/15 because the width increase changes the ratio.
185/= width, 60/= aspect ratio, and 15/= rim size. excuse the spelling.
Old 04-24-2005 | 05:13 PM
ootsae's Avatar
Has anyone tried stock rims with larger tires ie 205/70/15 ?
Old 04-24-2005 | 07:34 PM
hotbox05's Avatar
205/70 will be soo huge both width wise and heighth , theyd be very baloony looking and feeling you will lose alot of cornering stats. it would become unsafe and imo look like crap i'd say a 195/60 would be the best without going overboard. maybe even 205/60 or 195/70 but those still scare me.
Old 04-25-2005 | 01:54 AM
djct_watt's Avatar
Team Sushi
IE 185 - 60 - 15
or
First three numbers indicate tire width, in millimeters, ie 185.
Second two numbers indicate sidewall height, which is measured in an aspect ratio, or percentage of the width. IE, 60% of 185.
The last number is the radius of the wheel it is supposed to be mounted on, ie 15 inches.
Old 04-25-2005 | 03:41 AM
ootsae's Avatar
Originally Posted by djct_watt
IE 185 - 60 - 15
or
wow that is a lot different than what I said.
Old 04-25-2005 | 03:46 AM
ootsae's Avatar
don't you rember the muscle cars, large raised white letter tires of 15" riims? I think that would look too cool if I can match up tires to wheel wells just right.
Old 04-25-2005 | 03:49 AM
hotbox05's Avatar
yeah but they were rwd and could push big ol tires like that , lol. i've actually been workin on my uncles 71 nova the last few weekends just got an rpm air gap manifold , 600cfm 4 barrel , and some other goodies.
Old 04-25-2005 | 04:55 AM
ootsae's Avatar
very cool, I fiigure with one turbo and some zip gas those big tires will turnover at least once.
Old 04-25-2005 | 05:33 AM
hotbox05's Avatar
nah it should work just be a little scary in the turns cuz theyre soo tall is all.
WRX1316_TcVicent
07-22-2021 06:06 PM
a23r
02-01-2016 04:05 AM
KSwag
09-01-2015 08:04 PM
javio24
08-13-2015 05:27 PM
Quick Reply: Different Gears
