Do I have a coolant issue?
Seven City Scions
My engine has always like all the other XB's I know of started up with a Blue coolant level light which I know to mean the engine is just not at optimal temp yet. Well, within the past two weeks the weather has been getting much colder here, and now when I turn on the car the light stays red for about a full 15 seconds after the engine has already been started and then goes to blue for about 3 min (which it's always stayed on for about 3 min since I bought it)
I was under the impression that the red indicator mean BAD! Anyone know why this may be coming on then going away at first start now?
not sure, but you could have a bad thermostat that is not opening all the way or something. no way to check except to take the hoses off and look at it (not easy). hopefully someone else will chime in with another possibility.
Mine comes on red for maybe 3 sec sometimes. It's not the thermastat, that's mechanical and not wired to the dash. it may just be normal behavior, your engine isn't overheating in the first 15 sec of startup. it may be a bad water temp. sensor. Even though we don't have a gauge, it does read and go to the ECU, you can venn get a temp. reading with the scan tools. It's easy to replace if it is bad, just screws in to the side of the block, you may need to remove the stock air box to get to it though.
Are you getting any check engine lights that would indicate the water temp sensor throwing a code? If not, I wouldn't worry about it. The thermastat will still work even if the sensor doesn't.
Seven City Scions
I haven't gotten any CEL's in about 3k mi. I got a few of the VSC, and CEL's but turned out they were from my dumb ___ not tightening down the gas cap all the way. At least that's what I thought because I haven't gotten one in months. I don't know I'll keep an eye on it and if something happens I'll post an update.
50/50 coolant mix dose not start to boil over till you hit 202f. a scangauge would help you keep an eye on your coolant temp. and also lets you keep an eye on almost every thing your motor/car is doing and scans for codes.
Just a couple of guesses...
Does the xb have a coolant level sensor in the reservoir? If it does, the red overheat light might also be used to indicate low level or bad level sensor. I don't see any reference in the owner's manual for anything other than overheating though.
If the coolant was changed, could be air trapped in the system causing an incorrect sensor reading?
You could check the connection to the sensor and see if that's loose or corroded.
Like BlueJDMBoxV2 said, if you had a scangauge, you could see the temperature the sensor is reading. It's a cheap investment, given the xb's lack of gauges and the ability to display and clear codes.
I don't have any other suggestions, but I can deffinitively say that it's not overheating in the first three seconds of startup. You can mark that off the list. A bad sensor can do all kinds of weird things, but don't worry about damage due to overheating in the first three seconds.
xB doesn't have a coolant level sensor.
The blue light will stay on untill the coolant temp reaches 138F. The overheating red light is a different LED and should stay on for few seconds after you start the car just to show that it's working. 15 seconds seem a little too long, but that's most likely decided by the microprocessor in the cluster, so it's probably just an issue with the internal timer.
Would be really good to connect a data reader, like the Scangauge to see what's the actual temp that ECM sees during first few seconds after start.
jspadaro
03-11-2015 06:04 PM
mrsocks
01-20-2015 01:29 PM
CharlieMurphy
10
03-31-2004 03:05 PM
