Does Autozone sell Denso plugs under the Autolite namebrand?
I found the correct Iridium plug ofr my xB as Denso model 5303 gapped .035 and then searched 5303 on Autozone's website to see if they stocked them. And it brought this up.
http://www.autozone.com/autozone/cat...14&totalPages=[I@798c3¤tPage=1&vehicleNValue=&sortType=null&fromType=oem&navValue=14200033&parentId=cat10003&fromString=search&filterByKeyWord=5303&categoryNValue=14299999&categoryDisplayName=Routine+Maintenance&_requestid=1472233
Is that a rebranded Denso Iridium plug sold as Autolite? Or should I stay away from this product.
A spark plug is a spark plug and does it's job as a spark plug.
Snoodge definition from the urban dictionary...
a loose cigarett , sometimes known as a loosy
AKA ; loosy, cigarette, square,smoke, ___
Well I read your post.
The Denso with the .044 gap is not the plug Denso reccomends for our car anyway. Search on the Denso website. They reccomend a .029 gapped plug. I figured the .035 gapped plug was somewhere right in the middle and thats the Denso that SparkPlugs.com reccomends for the xB if you want an iridium plug.
I want to change my plugs becase the car has 35k on the odo and I figured I may as well change em and then use them to over 100k if I get Iridium plugs.
that is odd because the 2005
2006
Odd
2005 SCION XB 1.5 L - L4 1NZFE K16R-U11 PK16R11 SK16R11 IK16 0.044
2006 SCION XB 1.5 L - L4 1NZFE K16R-U PK16R8 SK16PR-F8 IK16 0.028
First of all, I was just kidding, hence the smiley face.
Second of all...
Lets think about this for a second, 04-07 are the same exact engine. The factory gap spec is .031.
.028 is a lot closer to .031 then .044 is.
Which one do you think is more likely in error?
Deductive logic > this thread
Second of all...
Hey frogbox, are you going to continue dancing around my responses or address them directly.
The Denso website obviously lists different plugs for the different years. 04/05/06. is there any reason you can think of that 05' would be reccomending .044 and 06' would be reccomending .029?
Do you think there could have been a fuel system or ignition system change that nessecitated a plug gap change?
Im trying to understand because it affects which plugs people choose. You cant just blanket reccomend .044 when thats not what even Denso is reccomending.
If I remember correctly.... didn't the 06's change over to a CAN-BUS Ecu control system? I know that there is infact a difference in the pinout between the 05 and 06 Ecu's, maybe the minor differences affect how the Ecu controls ignition timing and other such aspects. Just my .02.
Your owners manual is a great source of information people...read it!
Worst advice EVER! Put some Champion plugs in your box and tell me if you still think a spark plug is a spark plug.
