Electric Supercharger
Old 02-20-2005 | 03:38 AM
engifineer's Avatar
Originally Posted by dgHotLava
these do work but only get us about 5hp...
(the stock alternator is 80 amps...normal darw while car is running is 38 amps...it has plenty to sapre without inducing a load...)
these are about 1/10 the price of a turbo....
if you want to tune, go ahead and try it...but its a lot of work for little result. just get a regular intake for about the same performance (and a better look)
The alternator is RATED at 80 amps. You are only using what is needed. So if normal draw is 38 amps, then adding to that will always induce more load regardless of the rating of the alternator. The maximum capacity of the alternator has no effect on this. The conservation of energy laws apply to any system, more power out has to mean more power in. So any addition to the draw on the electrical system means that the engine will have to use more power to keep up. As mentioned in a reply above, you would be better off with a super charger or turbo. But contrary to popular belief, the exhaust pressure used to move a turbo is not completey free. You are adding restriction to the exhaust system, which robs some power. Turbos are inherently more efficient however because they make better use of the power from the exhaust than the supercharger does from the power used by the engine to turn the belt drive.
These electric blowers are complete ripoffs, dont get fooled by them.
Old 02-20-2005 | 03:39 AM
C_Monsta's Avatar
Originally Posted by McBain
Originally Posted by Kong
Here is a quote from the website :
"Finally, unlike any other manufacturer of "bolt-on" performance additions, we GUARANTEE you will see AT LEAST a 4% increase in horsepower by adding the e-RAM on your intake or we will give you your money back!*"
4% increase in HP... WOW! Where can I throw my money away to get this! These units are really not very effective... The drain on the engine from the alternator which powers the unit negates MOST of the benefit. A turbo is much more efficient because it uses exhaust gases which is basically free power.
Exhaust gasses are far from "free power" you have to consume gas to produce exhaust, and gas is alot more expensive then battery juice
Old 02-20-2005 | 04:51 AM
jct's Avatar
jct
snake oil!!!
Old 02-20-2005 | 05:36 AM
KingLou's Avatar
Intakes are about 4...... whp.
In your dreams... 4 flywheel HP maybe... not to the wheels
Dude learn how to read dyno charts. Relax and let people do what they want.
Haha.. dynos ... they have an accuracy rate thats differs more than 5% for the SAME dyno between runs. Not to mention temp , baro, and other variables. I know, I used to have one in my shop. So you go ahead and believe the dyno charts and some advertisement... it will make you believe you have more power.
And don't worry, Im relaxed from all the laughing... Thanks!
Hey McBain..........I've been in contact with numerous performance shops who have done repeated dyno testing on different cold air intake systems for Scions.............and they all said the same thing, which is as follows:
"Tell that idiot McBain to shut up cause he's an annoying troll."
I'll take those results to the bank.
KiL
Old 02-20-2005 | 12:14 PM
dgHotLava's Avatar
Originally Posted by hornet_on_flower
snake oil!!!
that one caught me off guard....
hey MCBAIN,
if you had a dyno in your shop then you should know what works and doesn't.
so instead of being a hater why not help the community with usefull knowledge of performance products....
Old 02-20-2005 | 02:13 PM
Kong's Avatar
You guys might be able to try this for free, especially if you want to dyno your car. They said that if anyone can prove that it doesn't work, they will give a full refund and pay half of the dyno cost.
Old 02-20-2005 | 02:27 PM
mikem53's Avatar
I haven't dynoed the box and I don't plan to. But I have had my Z06 dynoed at two different shops within the same week. Both on dynojet models. I wanted to get some baseline numbers while the car was all stock with 3K imles on it.
At the first shop I dynoed 368 rwhp ( I love this car!) each of the 3 pulls were different. The LS6 engine actually produces more power hot so my last run was the best.
The second shop with the same dyonjet which was just updated and calibrated, also had new sensors and I pulled a 363rwhp on my 2nd run. Similar weather during the week and both shops used a large fan to circulate air.
So there are differences between dynos even if they are the same model. At least from my experiences....
Old 02-20-2005 | 02:33 PM
mikem53's Avatar
You stated the obvious... He did say "basically free" power... there is a difference.. you still have to create the exhaust flow regardless of having a turbo or not. A turbo is a restriction in the exhaust path and is not a totally free source of power. Battery juice is not free as the alternator is under load to create the power for the blower... that load equates to powere loss and more fuel.
Old 02-20-2005 | 09:02 PM
George's Avatar
Default Re: Electric Supercharger
I saw this in the Turbo magazine. I think, you guy might be interested.
http://www.electricsupercharger.com/
It seems to be a cheap alternative to the real supercharger, with 1-1.7 psi of boost.
Cheap, and not terribly effective.
Let's say that it gives you 1 PSI of boost. Atmospheric pressure is about 15 PSI, so at best you will be putting 16 PSI into the engine.
The power an engine puts out depends upon the air you put in, and one PSI of boost means that you can put 16/15 as much air into the engine as you did before. The maximum power you get out will therefore be 108 (16/15) or 115 HP.
However, from this you have to subtract the power consumed by the blower, which comes from the alternator. The claim 38 amps draw, which is 38*14=532W or a bit less than one HP. This seems awfully low to me, as conventional superchargers take twenty times as much power to produce 5 PSI boost. In any case, your maximum horsepower gain would be 115-1-108 or 6 HP.
Now, this number seems respectable, but I have severe doubts that this device can supply 1PSI throughout the power range of the engine. Can it really supply the 75 liters per second of air under pressure that the engine needs?
Also, a continuous 38A additional draw on the alternator isn't something to take lightly. Yes, the alternator can provide that much current, but it is designed to produce it only for short periods to recharge the battery after the car is started. Supplying that kind of additional demand continuously invites electrical problems.
Old 02-21-2005 | 12:16 AM
Kong's Avatar
Thanks George. That's what I wanted to hear. According to the website, it use a contact switch to activate the blower and it is set at full throttle. This is the only condition that the car will gives enough power to supply the blower. If it is turned on at other time, it will either drain the battery or the car may not run properly.
Old 02-21-2005 | 12:10 PM
McBain's Avatar
KiL
Well boylou, I'm sure the many performance shops you contacted who have done repeated testing on products that keep them in business gave you a fair and realistic answer to your questions. They would not be biased in any way. Especially if they sell these products. Thanks for doing all this valuable scientific research. Very useful for everyone.
The only thing you get to take to the bank is your money to pay for the many worthless items you seem to be so fond of. Good job!
Old 02-21-2005 | 12:30 PM
McBain's Avatar
snake oil!!!
hey MCBAIN,
It is not a question of being a hater. I am stating the obvious and being factual. For example. read this post. I said there would be no gains do to the fact that the blower will draw more engine power thru the alternator then it will produce. Many others said the same thing. Its a fact.
Yet some on here will cry and call me a hater because they don't want to hear the truth. Some of these mods just don't work. period. People just don't like to hear that. I design and manufacturer performance parts for select racing teams. Its what I do for a living. We don't worry about the aspects of drivability or passing smog tests. We are performance 100%. We have to extract all the gains possible from every aspect of the engine and driveline.
We have to know what works and what doesn't just to stay alive in this very competitive business. One too many losses and your history. We have been in business for 35 years and still growing strong. We didn't get there by adding expensive parts that didn't work. There is much engineering that goes into an engine system. You can't just change one or two pieces and expect it to make a difference. The engine works as a system and all aspects must be considered.
I enjoy all cars and like sharing information with others... at least I thought I did. I may come off as an old grouch, but I know what I'm talking about....
Nothing wrong with doing some mods on these cars or on a lawnmower engine... just don't expect big results if any.
Mods must be thought out and their effects must be considered for other parts of the system. A huge intake manifold doesn't help if the valves are too small or the cam duration is too short or the exhust system is too small. In fact it can hurt performance by changing the velocity of the intake charge.. There are so many cause and effect issues to consdier...
Old 02-21-2005 | 03:17 PM
dgHotLava's Avatar
ok, i am starting to see some light ....
you are correct in that one mod alone will not make it a sleeper...it often has cascading effects to follow...
thus the most common Intake, Header and Exhaust go hand in hand....
maybe your employer would like to develop some parts for us....
Old 02-21-2005 | 05:59 PM
KingLou's Avatar
What items are those exactly? Where did I say I was fond of any items?
KiL
Old 02-20-2006 | 10:20 PM
Carviperblue's Avatar
I looked into these a couple of years ago. They will work on small engins like ours. The problem is when your not using it. The turbine in the intake blocks the incoming air. Under normal driving conditions your intake will be restricted to apprx. 15% of normal flow. When you stomp on the gas the turbine will spin up and give you 120% flow. This would be a good mod for a drag car! If you are at WOT all the time it works.
Old 02-21-2006 | 02:38 AM
Sciond's Avatar
reading this thread gave me a headache
Old 02-23-2006 | 04:23 AM
xbjoker's Avatar
Default electric supercharger
I talked to the guy at the company, they've been doing this since around 1995.
They started doing it in porsches in the scca class.The new models have improved since this firts ones.If you watch the video this fan lifts itself off the ground.
It only comes on at full throttle because you'r butterfly is completely open then.
keep in mind this was originally built for racing, comes on to help you out of corners.
Also helps off the line or when ever you punch it. They've also developed a super model which is two fans together to give you twice as much. I am very interested but
probably would be the last thing done. I think its worth looking at and take a look at
the customer feed back. The only good one to me seems to be the e ram.
Old 02-23-2006 | 02:30 PM
jwa276's Avatar
+1
Old 02-23-2006 | 03:01 PM
engifineer's Avatar
I am glad that someone actually took the time above to point out the 1HP it is wasting coupled with the very few it may produce. Now.. you are also adding 38amps draw to the charging system.. sorry, but I still dont see getting any benefit from this... most likely no noticeable gain and a charging system worn out much faster than normal.
Remember the guy who used a leaf blower on his car one the dyno? Well, most leaf blowers I know of have a much higher volume than I expect to see from that cheap fan and run at LEAST a few HP... he turned a whopping 10WHP with it.
But hey.. its funny that people "sell" this stuff. And you can ignore the "testamonials". The turbonator people also have "testamonials". My favorite was a guy claiming he gained 20WHP AND shaved over a second off his 1/4 mile time..... the two lies he told dont even coincide with one another...
rain7905643
06-13-2018 05:29 AM
deademon
03-31-2016 09:25 PM
corbinortiz
10-02-2015 02:45 PM
MisterSkiz
09-27-2015 10:25 PM
Wrencher
07-29-2015 01:38 PM
Quick Reply: Electric Supercharger
