Exhaust moves & rubs rear gound effects
Anyone else having this problem of your exhaust tip moving to the right and once in awhile rubbing the rear ground effects?
I have a HKS Hi-Power exhaust. This started about 3 months after I put it on. I need a fix for this if anyone has one. Thanks
Manny('05 xB)
Manny('05 xB)
The only things I could think of is that the rubber portion for the exhaust hangers are worn or the exhaust is not seated properly, or while installing the exhaust you got grease in between the rubber and the hanger causing it to move abit.
I also have this issue with my strup v1 but it has that slant and hangs really low and did not want to take away from the look so i just left mine,It has some light melting around but ehhh!! so minor to notice unless you zero in on that area.Also be aware of the gasket if its a rear only section muffler when it moves around alot it will tear the gasket up
I guess I could buy a new rubber hanger. It was a pain to put on though.
Thanks
Thanks
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
