front wheel bearings
Hey all I have an 05 with 108k on the clock. I'm about to order up some wheel bearings. I'm wondering if each hub takes one or 2 bearings? Im about to pick up a press!! does any one have an exploded view or a diy pictorial of the hub by chance?
Fantastic! thanks for the reply. I just bought my press today and will prob order a pair of bearings to do the front wheels. Ill see if I can post a DIY how to for anyone else not wanting to pay for a shop to touch their ride!
Remember , bearing to steering knuckle then hub to bearing.
They press in from opposite directions.
Don't forget to pull the cir-clip ( you should replace it anyway while in there.)
If you use a slide hammer to pull the hub first it, before removing the steering knuckle, will make it easier. Just bolt it to your lug studs.
Have fun , been there, done that. Took about 4 hours total time from parking to driving.
Don't all hubs have an inner and outer bearing race to support the hub on the axle? My motorcycles and boat trailer do, and so does my Subaru Forester. So I assume my xB does, too. So that would be an inner and outer bearing, a set of two bearings, for each hub.
And inside they are BALL BEARINGS not the roller bearings we are use to.
ok just so i have it right.... one bearing per hub and the hub is pressed on in one direction and the bearing is pressed from the other correct? what size circlip is it so i can pick some up before i begin? any other tips or parts required?
fur_pig
03-20-2020 04:28 PM
xdejablu3x
04-19-2017 03:44 PM
